I have 2 tripower setups, a 64 and a 66. The pic is the 64. I know what the 702xxxx means, but what about the letters/numbers stamped between the embossed lines at the bottom of the tag? Is there a data sheet listing these numbers?
This may help some.
Thanks Kenth, I thought that might be a date code but had no clue on the others.
Starting about 1957, the tags are also color-coded.
Jon
"Good carburetion is fuelish hot air". ![]() "The most expensive carburetor is the wrong one given to you by your neighbor". If you truly believe that "one size fits all" try walking a mile in your spouse's shoes! Owner of The Carburetor Shop, LLC (of Missouri). Current caretaker of the remains of Stromberg Caburetor, and custodian of the existing Carter and Kingston carburetor drawings. |
