What gets sealed on a convertible?
I know the top windshield header gets caulking. What else on the convertible trim gets sealed? A pillar panel?
67 LeMans convertible. Tyrol blue, M22z autogear, 2.73 8.5, 455, FAST MPI fuel injection. 243/ 251 112. solid roller. SD performance ported 6x heads. |
The only real caulking is to hold the windshield in place. The top seals to the header with a rubber weatherstrip, and uses rubber weatherstrips to seal at the A pillar and at the tops of the windows.
Jeff |
The windshield Top Molding and end caps as well as the A-Pillar trim had a Dum Dum type sealant.
This can be found in various widths and thicknesses As mentioned it's not a "Caulk" per se more of a pliable sealant putty in tape form.
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. |
Ok. Those are the pieces I was thinking that got sealant. Just double checking. I have the 3M strip caulk. Thanks
