I'm wondering if I can use a later model flywheel on my 1960 engine. I could compensate for the different ring gear tooth count by changing the starter drive or changing ring gear and the difference in register hole diameter could easily be overcome with a small adapter ring machined locally. My concerns are offset at the ring gear [for starter engagement] and bolt pattern. Anybody ever try this?
Roll around in the excitement
Roll around in the excitement |
Yeah, Bud. The 60 flywheel will have a smaller center hole than the 63 and up flywheel. Let me know if you find that 60 flywheel...I'd be interested in purchasing it if it's for sale...thanks
the date code was on the back
Bud.....check your e-mail. I'll take the flywheel.
Bud...flywheel arrived and I'll be sending the cash-ola along directly... interesting packageing job. I haven't opened it yet..probably this evening. Thank you.
how can you visually tell the difference in a 60 flywheel verses a later one, 64-up.i took a 60 motor apart about 10 years ago and i don't have the bellhousing but i might have the flywheel in my very unorganized shed.i'm not sure but i will look tomorrow when i go to where my cars are. i also know where there is a 56 3 speed car but i think the fellow wants to get rid of the whole car, its very rusty and would be a handful to move. if the flywheel would work i'll give him a call if i can't fix you up
bud, remember about 15 yrs ago i put the 63 ambulance motor in my red 62 car? the 62 flywheel wouldn't fit over the 63 crankshaft. i took both to the machine shop and ask them to fix me up. they bored the center out of the 62 flywheel to match the 63. if i remember right, they told me they took out about .030(i think). if you measure the center hole in a 63 up flywheel, it should be about .030 larger than the 62 back. at least that's how i remember it. don't know if this helps. don
