Old 07-04-2004, 07:59 AM
GNvsTA GNvsTA is offline
I have the powder blue interior in my 78 Formula. I believe that it is similar to the Skybird interior. It has the perforated vinyl. The headliner is starting to fall. I have been to two reputable shops in my area and both told me that they cannot get the powder blue vinyl. One then said that he can take white and dye it or replace it with powder blue cloth. I'm not sure about dying it and would really like to stay with the original material. The other shop said that dying it would not work well, plus the foamed backed vinyl does not adhere well to the board when replaced. I also asked about the bow conversion kits and was told they aren't all that great. If anyone has any advice, I really need it. Thanks!!
78 Firebird Formula-Cameo white
98 Trans Am-Arctic white
77 Grand Prix SJ-Brentwood brown met
Old 07-05-2004, 06:35 PM
The biggest adehsion issue is the vinyl actually has a foam backing. It breaks down like al foam does and some is stuck to the vinyl and some to the cardboard.
Old 07-05-2004, 04:43 PM
Colin's Avatar
Colin Colin is offline
Location: The ObamaNation we once called the United States of America
Get one of the ABS plastic boards and ditch the cardboard and adheasion shouldnt be an issue.
"It is foolish and wrong to mourn the men who died. Rather we should thank God that such men lived."- General George Patton
"Perpetual peace is a futile dream."-General George Patton
"I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them."-Thomas Jefferson
"Any society that would give up a little liberty to gain a little security deserves neither and will loose both."-Benjamin Franklin
Old 07-06-2004, 03:48 PM
Trim shops I've seen use a circular sander to knock off the foam on the cardboard.Then spray adhesive on and lay the material down. The correct headliner vinyl and cloth I have seen uses a foam in it that is usually the culprit for the sagging and separation.
Old 07-04-2004, 07:12 PM
Philo Philo is offline
I have a '79 TA with the same condition you have. I wanted to keep the original look too, but could not find a replacement vinyl, so I used a 1/4" thick backed fabric that was a 99% color match, from Jo Ann Fabrics. I like it much better than the vinyl, and it looks better too. Let me know if you decide to go this way and I will explain how I glued it and kept all bubbles out (if you need the info).
Old 07-07-2004, 12:37 PM
I was having trouble replying - not sure if it is a problem with the forum server or my PC.
Anyway, the process I used:
I removed all of the loose stuff from the pressed board, and stapled it to one end of a sheet of plywood to hold it. Then I applied the glue and let it set up (tack). Use a glue suitable for cloth and pressed wood and one that will tack up, but not dry for an hour or so. (I don't recall what I used, but it gave off fumes for a day or so until it dried. Since then, no smell). I then put the fabric on the other end of the plywood (good side down), with the edge near the glue. I put a pipe (2" steel, five feet long) on the plywood under the fabric. Wrap the edge of the material part way around the pipe, lining up the pipe and material so it is aligned with the pressed board. Then just roll the pipe slowly (use a friend on the other end) across the pressed board and glue. Try it first with out glue to see how it works for you. Don't press too hard on the pipe - just go slowly and with very slight pressure. Then allow a couple of days for the glue to dry completely before installing it - otherwise you could get finger dents in the material when you press on it. After you pull the pressed board off the plywood, you may want to clip off the ends of the staples - I only used about six staples. Good luck.
My visors are vinyl and in good shape, so I did not cover them.
Old 07-04-2004, 08:59 PM
I always wondered if you couldn't scrape off all the foam remnants and just glue the vinyl to the cardboard.
Old 07-04-2004, 09:25 PM
My post got a wording kick for 10 minutes for some reason.
Old 07-07-2004, 08:29 PM
Thanks for the instructions. Now I just have to find the material. Checked all the Joann's around me. None carry anything close to light blue.
Old 07-06-2004, 07:27 AM
Philo, can you email me the process you used. Looks like that is the path I will have to take. Did you do the visors too? Where can I get those ABS boards?
Old 07-08-2004, 06:34 AM
Rob79TA Rob79TA is offline
The glue that shops use to instal headliner cloth to the board is just contact cement. you spray the board and than the back of the cloth wait 15 min and aply the cloth to the board.
Old 07-06-2004, 05:39 AM
trumpeter trumpeter is offline
I also replaced my headliner with the JoAnne fabrics material. If you are careful, you can peel one layer of the old cardboard off taking with it any remaining foam backing. Then just glue it up.
I would love to try one of the new ABS boards, but have used the money for the motor...
I have a few pics of this process on my member page on the TAC website.
Trumpeter
Trumpeter
