| The Body Shop TECH General questions that don't fit in any other forum |
Here is my 68 GTO corner patch that took a while for me to do, but I'm happy with it. Butt welded in. First pic is of the rust.
Project "Thanks Dad!" |
There are guys in the parts for sale area that will have these. look through some threads or just post asking for the parts...
"My ol' man is a television repairman...he has an ultimate set of tools!....I can fix it..." J. Spicholi |
Second pic.
Nice job dude, good fab work!!!
East Coast Mafia TTFMF Making CVWHAT's great again. I guess it took a deplorable ECM member to do it! Quote:
![]() Fastest Blow-thru Pontiac powered car in the Country [email protected] (3465lbs) Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: [email protected]/ [email protected] (3365lbs) |
Thanks for the replies.
Greg, It was cut from a donor car. Then I cut and trimmed it to fit. Took a long time. Troy, This was welded from the outside. Like I said, it took a long time to cut out and fit. Then I just kept tack welding and grinding until the seam was welded shut. I've been using a thin cut off wheel to grind my welds down. The same one I used to cut out the rust. I don't know if anyone else does this or not, but its the only thing I had to grind with. Thanks.
GDK_AL,
I have a 3M roloc, but I havn't used it to grind with. I'll have to get some grinding disks and try it. Thanks for the tip. Great web site. I use it often to look at what you did to the 1/4 panels. Thanks.
Did you weld that from the back side?
How did you get it to look so nice?
Bring back my 67 GTO: Shes ALIVE as of 2-19-13 previously owned 78 Firebird 67 Nova 64 Nova |
A tight fit can work for MIG, howevber, I like about 1/16". It is all about penetration of the weld. If your heat is set right, you will get the penetration needed even if the fit is real close.
Pete's Ponies Mustang RUSToration & Performance |
Nice work...my first patch doesn't look so good yet. Stay tuned for a post titled RF fender patch
Nice work! ..
I have the same patch to do on my 68 convert. Judas sent me a nice pre-formed patch that will address most of the problem. Its on tap for as soon as I put the car down for the winter.
68 GTO ragtop 91 T/A 69 XKE |
Looks really good. Did you form the patch or did you cut it from a donor?
My '68 has a rust problem in the same area. Several areas in fact but I dread trying to start cutting on my car for fear I'll make things worse.
Greg Reid Palmetto, Georgia |
Third pic.
Good Job
"Don't let fatigue make a coward of you." |
The only reason I asked if you did it from the back is beacuse it did not look like you had a wide enough gap between the 2 pieces to butt weld them.
I have the same problem on my 68 convertible. I'm looking for that corner piece from a donor car. I need both sides. Does anyone out there have this to spare, or know where I could get it?. Thanks
Good work!!! Looks great!!!
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by 68droptop:
I've been using a thin cut off wheel to grind my welds down. The same one I used to cut out the rust. I don't know if anyone else does this or not, but its the only thing I had to grind with. <HR></BLOCKQUOTE> Visit your local automotive paint and body supply store, pick up the 3M Roloc discs for grinding. Although the cut-off wheel on a die-grinder comes in handly for tight spots I would really recommend the Rolocs for areas like you have done on the corner. With the various grtis available you'll spend less time grinding or worrying about the cut-off wheel gouging your nice work. Visit the 3M web site or look here for a nice sample of the Roloc line. Keep in mind there is a special madral required to use the Roloc discs. Chuck that into your die-grinder and you will never go back to a cut-off wheel for grining. Darryl |
Very nice work. I like to see others take on the challenge of these repairs. Keep it up.
Bill
_____________________________ It is not a problem.... It is just a blood pressure monitor. |
Last one.
