Old 04-08-2005, 10:46 PM
10secbird's Avatar
10secbird 10secbird is offline
What is the best method to remove a rear window on a 68 Firebird. I have never removed a front or rear window and am fearful of breaking it. I need to remove it to do body work/rust repair.
10secbird's Avatar
Old 04-09-2005, 09:30 AM
dansgto1972 dansgto1972 is offline
you can also use this tool specially designed for windshield removal, I bought it as recommended from another post here and it worked great..although I also heard that the piano wire trick works really well too...
http://www.amazon.com/exec/obidos/tg...72722?v=glance
Old 04-09-2005, 04:38 PM
rzrektd rzrektd is offline
On Vacation
I used a piece of 20 or 22 gage stranded wire. You can find it in your local hardware store. IF you have enough reach and a long enough wire, you can do this yourself. Now for the real advice. Watch out if your window seam has molding studs. Needless to say I cut the window out nice and well, but cracked the window top to bottom went I tilted it out. It helped me make my decision on buying a new window, but if you plan to reuse the window it will kill your mood.
Old 04-09-2005, 12:01 PM
wlpsyp wlpsyp is offline
I used weed eater string
_____________________________
It is not a problem.... It is just a blood pressure monitor.
Old 04-09-2005, 09:12 PM
Tennesseestorm's Avatar
Tennesseestorm Tennesseestorm is offline
Location: extreme northeast Tennessee (Tri-Cities metro)
I had the rear window removed AND resealed on my old 1972 Buick for $50. at safe-lite autoglass. Luckily, they said there was no rust under there and the seal had simply failed.
I would imagine that they would come and remove it for about half of that and you would not have the fear that I had of shattering it. I have heard more horror stories of the front windshield cracking during removal, more than I have heard of the rear glass shattering.
My cars (or should I say "TANKS") -
72' Chevrolet Caprice Kingswood Estate 3-seat wagon (402)
73' Pontiac Grand Ville Custom 4dr hdtp (455)
90' Buick Century Custom 4dr sedan (3.3L)
95' Lincoln Town Car Signature Series (4.6L)
Old 04-09-2005, 03:23 AM
GTOster GTOster is offline
Two guys and a gutar string
or two guys and a Piano string
One inside and one outside put the wire thur and saw back and fourth around the window to break the seal
Just did it last week for front and back windshields had the both out in 30 min.
Paul
Old 04-09-2005, 09:02 PM
karl emerick karl emerick is offline
I have removed dozens of windows with the 2 man and a wire technique. it will work but often the wire will chip the edges of the glass. If weedeater string will hold up that is a preferably way to go for a one-shot removal. I had my glass guy get one the pros use of a similar style as seen on the link provided by dansgto72 with several different length blades. it looks like it will be a 'lifetime' tool and I can't believe I went this long without it.
Old 04-08-2005, 11:57 PM
Colin's Avatar
Colin Colin is offline
Location: The ObamaNation we once called the United States of America
On my '81 Firebird I used an old Army can opener and clamped a pair of vice grips to it. I worked my way around the glass from the outside then the inside. Had a friend help me lift it off the frame. You just need some type of either flexable blade or one that is bent to go in under the glass. I tried the guitar string meathod with no luck. I also tried a hacksaw blade with no luck, just wasnt stiff enough, kept breaking. A blade that will flex somewhat on a handle about 2 feet long would be ideal.
"It is foolish and wrong to mourn the men who died. Rather we should thank God that such men lived."- General George Patton
"Perpetual peace is a futile dream."-General George Patton
"I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them."-Thomas Jefferson
"Any society that would give up a little liberty to gain a little security deserves neither and will loose both."-Benjamin Franklin
Old 04-09-2005, 07:43 AM
4SLASH6's Avatar
4SLASH6 4SLASH6 is offline
or if your by yourself like I was......push wire thru,..then ball up on inside, and pull slowly around from outside with vise grips
70 GTO 400/[email protected]
