Old 05-23-2002, 08:15 AM
Derding's Avatar
Derding Derding is offline
I have a 68 Firebird with a 71 400. It's a 4 speed. I'm in need of a new carb. Should I purchase a carb with mechanical or vaccum secondaries?
Derding's Avatar
Old 05-23-2002, 08:58 AM
GTOPhil GTOPhil is offline
If its a Q-Jet, why not let Cliff Ruggles work his magic. I run one of his carbs...he can make a Q-Jet sing.
Old 05-23-2002, 10:45 AM
gold79TA gold79TA is offline
Most of the experts here will tell you the pontiac quadrajet is the best for all around use. It is hard to beat the factory engineering. If you don't have one to rebuild a number of the people on this board can help you find the right one and even set it up for you. To answer your question that would then give you mechanical secondaries with air valves.
Old 05-23-2002, 06:18 PM
PROBRD PROBRD is offline
I always run a Holley with mechanical secondaries. [img]smile.gif[/img] I'm not real worried about gas mileage but all out performance!
1/8th mile 6.52 @ 104
1/4 mile 10.43 @ 128
Old 05-23-2002, 09:06 PM
Ditto to what probrd said.
