Old 11-16-2001, 11:16 PM
455Dave's Avatar
455Dave 455Dave is offline
I removed my aftermarket chrome valve covers from the 455 and the stock covers seem to be a bit short. Even though no oil drippers are installed on the factory covers, the roller rockers are hitting the lower edge of the covers slightly.
Two questions:
Since this is an AC car, the air conditioning to intake braket is pretty close to the passenger side valve cover. Does anyone make a thicker gasket that will cure this problem?
If not, any recommendations on tall covers that look a bit stock? If I use tall covers, I'll cut the AC bracket and modify it to fit. I'd rather use stock height valve covers, but the tick is driving me nuts.
Dave
Old 11-19-2001, 10:02 PM
Redlined455HO's Avatar
Redlined455HO Redlined455HO is offline
Dave
Use Felpro part # 1627 - thick cork gaskets, had to use them to clear my roller rockers.
Barry
66 Corvair Corsa - not so stock
74 Formula 400/4 sp - stock
79 TATA - almost stock
78 TA - owned it since new - not so stock (11.28 at 118.6)
Old 11-20-2001, 12:08 AM
Rocky Rotella's Avatar
Rocky Rotella Rocky Rotella is offline
Same here. I ordered mine from Nunzi which were $26/pr. No more clearance problems. You may find you need a bit longer bolt for the valve covers.
Old 11-20-2001, 12:30 AM
Gooatee's Avatar
Gooatee Gooatee is offline
Not sure how much clearence you need but, the Felpro #FPP-1627 is 1/4" thick as stated above and they are only @ $18.00 in Summit and Jegs!
455Dave's Avatar
Two questions:
Dave
Old 11-16-2001, 11:28 PM
Use 2 valvecover gaskets per valvecover.
or
Spotty has the extra thick gaskets for this situation.
Old 11-16-2001, 11:30 PM
455Dave's Avatar
If I use two gaskets, should I use some RTV between the two or will they seal up without?
Dave
