Old 10-03-2002, 07:06 PM
BLOWBAYOU BLOWBAYOU is offline
I'M WANTING TO CHANGE MY 71 LEMANS FROM AN AUTOMATIC TO A 4 SPEED. I HAVE SOME QUESTIONS I HOPE THAT SOMEONE COULD ANSWER.
1. THE ENGINE IS A 350 PONTIAC ENGINE. IS THE CRANK ALREADY DRILLED FOR A PILOT BEARING?
2. I HAVE A FLYWHEEL WITH A CASTING # 9779233.
CAN ANYONE I-D THIS NUMBER? DOES IT USE A 10 1/2 INCH CLUTCH OR 11 ? DOES IT MATTER?
Old 10-04-2002, 08:36 AM
the crank is drilled for the pilot bearing.
If the flywheel can fit a 400/455 crankflange, it will fit the 350 crank flange pattern.
10.4 vs 11.0 Pressure Plate...I dunno...is it a dual-pattern flywheel?
"11.00/123MPH/1.50 60foot/29.5"/4.10:1/10"/472 #48/Flat HYD/DualQuad/Wenzler/3250Lbs
12.00/112MPH/1.61 60foot/26"/3.31:1/10"/472 #48/FlatHYD/Q-Jet/Torker/3650Lbs"
Old 10-04-2002, 11:32 AM
WELL, I CAN REST EASIER NOW THAT I KNOW THE CRANK ISN'T GOING TO BE A PROBLEM!
AS FOR THE FLYWHEEL, IT CAME OFF OF A 69 GTO.
NO, IT ISN'T A DUAL BOLT PATTERN.
THANKS FOR YOUR INPUT!
