Old 09-21-2005, 03:43 PM
PLAY400's Avatar
PLAY400 PLAY400 is offline
Default Rod and main bearings scuffed
Tearing apart a 400 I had done but not run. Assembly was done by shop. I have what looks like sprocket marks, uneven scuffing (chatter) on my rod bearing and full scuffing on different sides of the mains. Not even across the surface but one side side of 1 bearing, other side of bearing on next journal etc. It's like the mains were polished on an angle.
To me the scuffing looks like the engine was put together tight. engine has not been run and was well oiled.
I have never put together a new rotating assembly nor torn 1 down before. What gives? Thanks Alan
Old 09-21-2005, 05:18 PM
wheelspin's Avatar
Question
Need some pics in order to help determine the cause and the appropiate fix.
Les
Les Iden
Old 09-21-2005, 07:43 PM
trim trim is offline
I am guessing that they put all of the rods on backwards and the scuffing is from the chamfer on the crank.
Old 09-22-2005, 08:42 PM
PLAY400's Avatar
Try to post pics of main and rod bearings. Motor has only been spun by hand.
ID:	27877   Click image for larger version
ID:	27878   Click image for larger version
ID:	27879   Click image for larger version
Old 09-22-2005, 08:44 PM
PLAY400's Avatar
last of them. Normal or problems?
ID:	27881   Click image for larger version
ID:	27882   Click image for larger version
ID:	27883   Click image for larger version
Old 09-22-2005, 11:38 PM
wheelspin's Avatar
Arrow
How much force did it take to rotate the assembled short block?
The minor scuffing does appear to be from tight bearing clearances or out of shape journals. First mic the bearing surfaces of the crank mains/journals/rod big ends and the assembled bearing shells to determine the existing bearing clearances. Some of the scuffing appears to be caused by poor housekeeping (debris) or mishandling the bearings. If in spec, clean the main and rod bearing shells, lightly Scotchbrite the obvious scuffs, assemble with a quality moly paste assembly lube, and be sure to prime the engine's oil galleries with a priming tool thru thru the dist. hole.
Les
Les Iden
Old 09-23-2005, 08:01 AM
pro-tour79's Avatar
pro-tour79 pro-tour79 is offline
.005 taper !!! that's more than the piston to wall clearance.
www.pro-touringf-body.com
Old 09-24-2005, 12:55 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Doesn't sound like they got much of anything right! I'll bet you're glad you needed to deck it, and thus tear into it, huh?
Old 09-24-2005, 10:04 AM
PLAY400's Avatar
You bet!! Would have run it, blown it, either piston or crank, taken back to the original shop and been told it was abuse and "you know Pontiac is famous for weak bottom ends". If shipping and Canadian Customs weren't such a pain I'd get on a program with 1 of the US builders on this site. SD is up here but I get the feeling David doesn't wants to bother with the little dogs anymore.
Old 09-24-2005, 11:55 PM
Oh well, keep educating yourself on Pontiacs, and put it together right ("right"="carefully"). There's a wealth of good stuff on these forums!
Old 09-25-2005, 08:16 AM
Geoff Geoff is offline
I cannot see that those marks would be made by the crank. From the pics, they look more like packaging marks. The soft bearing material is susceptible to corrosion & acid attack. Maybe other metal parts were in contact/rubbing during shipment? Galvanic action corrosion from unlike metal[s]?
