Old 10-17-2005, 09:58 AM
MRGTO2U MRGTO2U is offline
Default Speedometer Gear Help?
Hi everyone. I just installed a new Auburn Posi and 3.55 gear in my 68 GTO. Wow! what a difference going from a 2.78 open to the 3.55. Great acceleration! As you all know my speedometer is way off. Doing 45 MPH she marks almost at 60. What do I have to change, the speedometer gear? Is this the part I need:
3.55 1362049 42 GREEN X 1362293 PX 16
I found this from a chart at: http://www.teufert.net/speedo/68-gto-400.htm
This has both the Gear and the Sleeve and Seal Assy. My Tranny is a TH400.
I really appreciatte comments and advice. Thanks to all!!
JG
Do I need both the gear and the Sleeve and Seal????
Old 10-17-2005, 02:33 PM
screamingchief's Avatar
I always check this resource for my speedo gear needs:
http://www.tciauto.com/tech_info/speedo_gears.htm
You should replace the o-rings/seals when changing gear(s) for the sake of being thourough,but the sleave should'nt be needed necessarrily.
