Old 11-14-2005, 10:59 PM
Anselcop Anselcop is offline
Default Epoxy primer question
I just finished stripping the frame for my 69 GTO down to bare metal and I'm already starting to see some light flash rust only after a week or so. I was planning on stripping all the suspension parts and paint them all together, but I wont be able to get everything stripped down for at least a month yet. My question is, can I shoot the frame with epoxy primer to seal it and leave it sit for a month until I get everything else stripped; or do I only have a day or so before I need to spray the frame with a top coat after I use epoxy primer. I plan on using eastwood extreme chassis paint for a top coat.
Dan
Old 11-14-2005, 11:35 PM
formula400's Avatar
formula400 formula400 is offline
the eastwood paint is designed to go over bare metal,i recomend to use thier primer first,do not use self etching primer epoxy paint is designed to do what self etching does,i am currently using the eastwood paint the only issue i have come across is that it takes awhile for it to dry unless you crank the heat up or bake it,best thing to do is light coats until each coat dries or you wait for ever,you can prime it and paint when ever you want just scuff it with scotch brite first in case any dirt or grease got on the object you want to spray,hope this helps
Old 11-15-2005, 01:09 AM
Ron Landis's Avatar
Cool One note on primers...
they are made to absorb....paint...grease..moisture, whatever. Only paint or sealer will actually seal. Make no mistake.
Old 11-15-2005, 10:14 AM
PetesPonies PetesPonies is offline
Epoxy primer is the most durable and moisture resistant primer you can use. You can certainly leave the frame in epoxy for a month..hell a year would be no problem.
Pete's Ponies
Mustang RUSToration & Performance
Old 11-15-2005, 01:05 PM
Thanks for the responses.....Since you can obviously tell I have no paint experience, I'm assuming the epoxy primer will be compatible to the top coat of Eastwood Extreme black chassis paint then?
Old 11-15-2005, 05:13 PM
pmdclassics's Avatar
pmdclassics pmdclassics is offline
Also would epoxy primer be a good base for PPG paint?
TODD
Old 11-15-2005, 05:53 PM
CDJr's Avatar
CDJr CDJr is offline
A PPG primer would be...DP90 or such.
A friend will help you move...a GOOD friend will help you move a body.
Old 11-15-2005, 10:08 PM
carcrazy carcrazy is offline
You can go a long time with Epoxy. I used PPG DP 90 on my frame four years ago-still have not top coated. Looks great. (car has been garaged-not in the rain) Cured epoxies are generally compatable with most top coats.
Old 11-15-2005, 11:16 PM
Thanks Guys for the help!!!
Old 11-16-2005, 03:28 PM
FORSALE FORSALE is offline
There is a window of time when just about any primer based product has to be coated. Check the PPG pages. They will most likely require you scuff and reshoot a seal coat of the same product before topcoating. Not that it isn't done but if you go by their instructions that is the way to go. You do not want adhesion problems and have to respray.
If sprayed correctly the PPG DPLF in black looks a lot like the factory black shade. It isn't UV protected but how often does your frame see daylight?
Stick with one product. Just use the PPG straight through. Stay away from the quick fix stuff. If you are going through the trouble of taking down to bare metal do it right.
I do believe their etch primer can be left without primer for extended periods.
Old 11-24-2005, 08:42 AM
73superduty 73superduty is offline
ppg dp epoxy has a 7 day window before you need to recoat.
1969 gp manual
1970 gp auto
1973 4spd ta
1975 4spd ta
1969 gto auto
1978 4spd formula
1964 buick wagon
"always looking"
Old 11-28-2005, 06:43 PM
if you sand the primer, hense giving it mechanical bond, you can go outside the recoat window.
Pete's Ponies
