Old 02-01-2006, 05:33 PM
bigunde bigunde is offline
Default whats a 12 bolt posi worth?
I have a 12 bolt 2:56 posi pulled from a 68 olds 88 delmont.Was gonna throw it on ebay.Any idea what they are going for?
Old 02-01-2006, 09:37 PM
Pontiac signman Pontiac signman is offline
I'd say between $500-$750.
The small carrier offers less than the 3 or 4 series.
Good luck!
'67 Lemans Convertible...400, 4-spd, 3:23's
'67 Lemans HT...468, T-400, 9", currently being TUBBED!.....SELLING
'67 GTO HT...SOLD.............
'68 GTO Convertible...400, T-400, 12-bolt...SOLD.....
'70 R/A III Formula...Under Construction.....SOLD......
Old 02-01-2006, 09:51 PM
engineer engineer is offline
did not think Olds had a 12 bolt in a full size in 1968. later on from 1970 maybe
Old 02-02-2006, 09:50 AM
65gto69's Avatar
65gto69 65gto69 is offline
You have to be carefull with Olds 12 bolt rears. With an Olds rear you have to count the bolts on the ring gear inside the carrier. The 12 bolts on the back mean nothing on an Olds. For a true 12 bolt the ring gear should have 12 bolts holding it into place, a true 10 bolt will have 10 bolts holding the ring gear. So it is possible for the Olds rear to have 12 bolts holding the rear cover on, but when you unbolt it, count the bolts holding on the ring gear, 10 it is a 10 bolt, 12 it is a 12 bolt.
Hope this helps,
Mark
1965 GTO: 467 (Built By Dan Willever), 400 Block, Eagle 4.25 Stroke, Eagle 6.8 Rods, BRC Pistons, Custom Grind Hydraulic Roller Cam, Edelbrock 72cc Heads Ported, HS Rockers, Doug's Headers, Edelbrock Victor 4150, QTF 850 Carb, AutoGear M22 4 Speed, SPEC Clutch and Pressure Plate, 12 Bolt 3:73 Posi.
Old 02-02-2006, 11:27 AM
Good deal and thanks for the info.Ill try and pull the cover tonight.It seems to be in really good shape
Old 02-02-2006, 11:48 AM
pvan pvan is offline
Default 12 bolt posi value
maybe a 12 bolt for a big OLDS is around the value of a big Pontiac posi?
I have a drum to drum complete 2.93 posi from a 1970 Bonneville I bought for $425 from Franks Pontiac's in San Diego a few years ago plus I paid $170 freight.
I ran it for less then one summer and it runs out just fine but the brakes should be gone thru. I went to another rear end so if any of you guys want it you can have it for only $425 plus you pay the freight from zip 99206.
Paul
1969 Black Bonneville convertible 428HO
Old 02-03-2006, 06:16 AM
copper128 copper128 is offline
In a '68 Olds Delmont 88, what rearend you have depends on what engine the car originally had. 350 Delmonts got the 8.5" Olds 12-bolt (10-bolt ring gear). 455-powered cars had the 9 3/8" 12-bolt (12-bolt ring gear). They look very similar from outside, so pull the cover to be sure what you have. The 8.5" unit has good gear and posi availability, but the 9 3/8" is a junkyard availability-only piece. 3-series posis and gears are very rare for the big Olds rear.
Old 02-03-2006, 08:54 AM
good deal.the car came with a 455.
Old 02-03-2006, 05:48 PM
Oh well took the cover off.NO POSI.but it has 12 bolts and seems to be a 350 gear.42 teeth on the big one and 12 on the little one
Old 02-17-2006, 04:50 PM
Can you either get a pic of the info stamped on the side of the ring gear, or re-count the teeth? I'm thinking the pinion probably has 13 teeth instead of 12, which would make it a 3.23 ratio. There was no 3.50 ratio in an Olds rearend. I think the big-car gears were usually 2.56, 2.93, 3.23 or 3.42. If its a 3.23, I may be interested in just the carrier and gears.
