Old 07-25-2006, 09:20 AM
Laguna454s3 Laguna454s3 is offline
Default Band Clamps
Hi All. Has anyone used band clamps to couple two butted same size pipes together without connecting them male/female.
I considered this as an easy way to change mufflers as they would not be sliding into the pipe.
I'm an electrician and this is basically how tubing is connected.
Any thoughts or experience ?
John
Old 07-25-2006, 10:06 AM
meanolgoat meanolgoat is offline
I have only used the Band Clamps on Lap Joints, and will only use Band Clamps from now on. They work great.
Summits Web site lists the Butt Joint Band Clamps, with the Duramax Name, I would give Summit a call and see if they have any customer feedback on them.
http://store.summitracing.com/egnsea...429+4294919986
Old 07-25-2006, 11:31 AM
Tim john Tim john is offline
NAPA auto stores have them in stock (stainless steel) for $ 9.00 each. I have installed several in 2 1/2 inch size and they are very nice to work with and I have not had a leak issue in two years. I would reccomend them for your intentions and application.
Tim john---
Old 07-26-2006, 08:01 PM
Engine-Ear's Avatar
I second the NAPA band clamp route...they are Made in USA.
RediRad circuit designs, branding and intellectual property are for sale.
Serious inquiries only.
Old 07-27-2006, 10:42 PM
can_am4me can_am4me is offline
The band clamps work nice, although I have had some twisting of the pipes in the clamps. A couple of small sheet metal screws did the trick.
Putting some "Can do" in my Can Am
Old 07-29-2006, 09:20 AM
Thanks Guys
I plan on doing custom bent pipe and mounting the mufflers butt joint with the band clamps.
John
Old 07-30-2006, 04:03 PM
GRX's Avatar
GRX GRX is offline
Another vote for the NAPA clamps. Good luck with the project.
1969 GTO hard top ~ Std bore 400, '70-RA3 block, 670 heads, Bal. & Blue... M22, 12-bolt w/3:55s
Old 08-04-2006, 01:04 PM
I tried band clamps on a male/female junction that the female was a little loose, never sealed until I used an old fashioned clamp.
Old 08-04-2006, 02:45 PM
BVR421's Avatar
BVR421 BVR421 is offline
Ive seen special band clamps made for butt points advertised but Ive never used them
Old 08-05-2006, 01:12 AM
Ccass's Avatar
Ccass Ccass is offline
Administrator
The NAPA band clamp is a good one for this application. Pypes also has this same clamp available and it is one of the few that will seal properly with a butt connect.
Old 11-22-2006, 09:35 PM
Indiangoat Indiangoat is offline
I plan on connecting my 2 1/2 inch exhaust manifold downpipes (65 GTO) using the Napa butt joint band clamp, but I am wondering if the clamps will be strong enough to support the exhaust system since there are no hangers nearby. Has anybody had any problems with their exahust bending or breaking at band clamp connections?
Old 11-23-2006, 01:58 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Originally Posted by Indiangoat
... Has anybody had any problems with their exahust bending or breaking at band clamp connections?
I haven't used my S.S. band clamps yet, but from handling and inspecting them, I doubt you could ever bend/break them- assuming there will be at least SOME hangers in the system.
Old 11-23-2006, 01:41 PM
Ccass's Avatar
Administrator
There isn't a lot of weight at that point if the downpipes are secured to the manifolds and the mufflers are suppoerted by quality hangers. If you are still concerned, slip fit the downpipes and use a stepped band clamp.
Old 11-23-2006, 02:14 PM
Formula8's Avatar
Formula8 Formula8 is offline
I used the Summit clamps butt joint claims as I needed a 2.75" size. They worked perfectly.
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi.
