There is trans fluid sitting on my intake manifold!I could not figure how the hell it got there,I found out it's going up my kick down cable and dripping onto the intake.What is the cause of this?a leak?
Maybe a plugged vent?? That's what I would check first.
North Dakotas fastest REAL GTO 10.10 @ 131 MPH in the 1/4 Hoping to get it back together some year. www.jandjrepairandrestoration |
You might be sucking ATF through the vacuum modulator line. Pull the vacuum hose at the modulator and see if you have a leak. If so, replace the modulator. Another possibility might be the transmission dipstick popping out under hard throttle and venting ATF vapor on the manifold.
I'll check those things out,and let you know.
