Old 11-05-2006, 11:50 PM
Goat4three Goat4three is offline
Default divider plate clearance
have we come up with a standard tolerance for divider plate clearance? is .100" acceptable before compressing the gasket or should we shoot for less?
i just bought a flowkooler water pump and i am in the process of "adjusting" my divider plate. so far i'm at .080" down from .200", should i stop here or try to get closer,or am i too close?
"Second place is the first loser"
"That's no oil leak....that's just sweat from all that horsepower."
Old 11-06-2006, 09:11 AM
gearbanger's Avatar
gearbanger gearbanger is offline
I went for zero clearance with no gasket. Then put it together. Once I had it tighened down I gave the pump a spin and had no interferance at all. It runs super cool now
Old 11-06-2006, 10:29 AM
Suppose this is nice-to-know for the factory Iron-pump folks...
This issue is no matter when you use the REVISED modern aluminum pump:
The GMB pump has been improved by Flow-Kooler model # BRA-1649 sold by Summit:
The divider plate's function has been welded to the Impeller.
So, the impeller has a sheetmetal hat welded to it now.
So, I took out the OLD GMB aluminum pump, and installed this UPDATED pump into the Timing Cover with factory divider plate. No clerance issues.
My car hardly warms-up. HIS
Old 11-06-2006, 05:24 PM
so if i'm understanding what you're telling me, with the 1649 water pump, there is no need to adjust the divider plate due to the "hat" they welded on the impeller?
Old 11-06-2006, 07:00 PM
george kujanski's Avatar
Here's the way i see the pump design:
Any comments?
ID:	70802   Click image for larger version
ID:	70801   Click image for larger version
Old 11-06-2006, 09:40 PM
gearbanger's Avatar
That is correct George. Plate or no plate, you have to close that gap between the divider plate. Technically, if you have the plate welded to the impellar, you only need to clearance the divider plate around the center hole. If you have the open impellar design, that gap technically needs to be tighened up allong the whole surface of the impellar. That forces the water to stay in the veins and be pumped instead of just being mixed between the plate and the impellar.
Old 11-06-2006, 10:23 PM
so then i'll remove the gasket, go for zero clearance, and reinstall the gasket, divider plate and bolt it up to the timing cover, torque it and check for interference. do i have to worry about heat expansion changing any clearances? or... will i be alright with the .080" with the gasket in place as is?
Old 11-06-2006, 11:09 PM
Brett_ty's Avatar
Brett_ty Brett_ty is offline
: HIS
I am getting ready to pull my engine and am planning on replacing the water pump to a high-flow one...
Was initially thinking of the Milodan brand...but now I am thinking about this one..
Is that part # for a 455?
Old 11-06-2006, 11:23 PM
1649 is for aluminum and 1649CI is for cast iron. both will work for your 455.
Old 11-07-2006, 12:02 AM
Brett_ty's Avatar
I see that, went to the site and noticed that water pumps for pontiac come with a 4" or 4 1/2" shaft...getting the wrong one can mess up pully alignment (FK only comes with 4 1/2" shaft) Anyone know what was stock and how to know what you got..Went out to see if it was possible to measure the shaft...but I dont know what/where to start the measure point.
Old 11-07-2006, 09:12 AM
first of all, i believe the only pump with the 4" hub is on the '69 engine, the rest are 4.5"....i believe.
as for measuring, if the water pump is off of the car, start the measurement at the machined surface on the impeller side of the housing where the gasket would go and measure to flange surface where the fan would mount. for ease of measurement, use a straight edge and line it up on the flange and measure back to the housing.
hope this helps.
Old 11-08-2006, 08:23 AM
cejay825's Avatar
cejay825 cejay825 is offline
I didn't know they made a water pump like that. will pick one up. good info !
69 judge-RAIII Auto
69 conv 4spd a/c
66 conv TBI EFI
76 50th annv. T/A
Old 11-09-2006, 08:20 PM
Ratman's Avatar
Ratman Ratman is offline
I just tried to decrease the gap btwn the divider plates and the impeller this weekend. I was using a rubber mallet and got the clearence down to about .100. The car ran warmer than it was before I made the adjustment. My questions are: what kind of tool is everyone using to decrease the gap, and what should that gap ideally be. My next question, should the entire divider plate be manipulated down to meet the impeller, or just the inside edge. If anyone has pictures showing the ideal gap, I would appreciate it. I have been chasing this overheating problem for about 3 years, I have a stroker 400 pushing over 600 horses and connot afford to let it get hot. Please HELP!
Old 11-13-2006, 12:58 AM
Brett_ty's Avatar
So Goat4three...How did it end up? Any Tips/observations to make?
I bought a Flowkooler WP and a new stainless steel divider plate this weekend..when I pull my engine at the end of the month...I'll be adding the new WP and Plate in.
Old 11-14-2006, 11:25 PM
BRA-1649..still working after 1 week, no drips, no noises. Engine seems cooler in bumper-to-bumper traffic but that could be my swap to dual carbs and Idle ADJs.
Old 11-16-2006, 06:46 AM
Squidward's Avatar
I also assembled plate onto pump with no gasket, then got to whacking. I only whacked about a half inch around the center hole. I have no clearance problems due to heating or otherwise.
Besides, if there were any slow creeping clearance issues, the impeller would take care of that when contact was made.
Old 12-24-2006, 03:26 AM
hottrodd's Avatar
hottrodd hottrodd is offline
dumb question, but do they make a after-market highflow or revised pump that will work in a 67 8 bolt timing cover? I have seen in the catalogs that they make them for the 11 bolt but not the 8 ?
Old 12-24-2006, 05:46 AM
Geoff Geoff is offline
Have a look at the post 'Timing cover with Chev water pump'. Allows you to use a Chev pump, many possibilities.
