Just to throw my hat in the ring...
Picked up motor a couple of weeks ago from Jack Gaydosh..had to swap out some parts to get it ready for dyno.. My thanks and kudu's to Jack, he's always first class at whatever he does.. Without his help I wouldn't have this motor.. My thanks to Brad Wallace (Wallace Engine Co.) for his machine work,friendship, and input to New intake,headers, CSR pump, & dist. still on old motor.. Want to try out some stuff before switching to new bullet.. Hope to play with it at VMP... All Pontiac.com IAII block Crower billet 4.250 crank BBC Eagle rods Ross pistons & pins Custom ground Chet Herbert solid roller cam KRE D ports ..325 CFM set up for solid roller Cometic head gaskets Harland Sharp 1.5 rockers(for now) Jomar rocker stud girdle Bearing cam retainer plate ( Scott's) with billet timing chain set up Power Bond SFI damper Canton oil pan TCI flex plate Sorry no Stelka or fabed valve covers. Need "Old School" look for NSS classes... Old M/T covers will be back on after dyno...
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. Last edited by 60man; 03-21-2007 at 03:56 PM. |
Nice motor!! How tall are those ports? My KRE CNC E heads are 2.400 tall.
How wide are your ports ??
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
Looking good.
When's it going on the dyno?
Shooting for 2nd or 3rd week in April.... Jack will be there so I'm working along with him... This will be the first motor I have ever had dynoed !!! No hurry...trying to do it "right the first time"... Thanks again to Jack. John ....I take it you are a Wallace. Are you related by chance to Brad Wallace ?...Essex,MD.
Not that I know of.
Sounds like a smart guy though!
I forgot the actual width, and it has an intake bolted. I want to think they are the same width as the big SCE gasket that is 2.350 tall. I'd bet they would use the same dimensions. That's why the T2 and Tomahawk needed a little extra up top to seal.
Sounds like that motor is a little too big to blow out some long branches, even those big early SD types
Tri-Y's are also gone and trying to adapt some 2" Husler headers... will probably wind up with custom made set....$$$$ At any rate I have modified a Hooker Super comp set 1&3/4 for now, from a 68 GTO.... I had to weld up my Offie intake to get the height to match up !!! No problem with the Wenzler....
Real nice, can't wait for some numbers.
Maybe measure it with a USA ruler - might measure different.
I curious about some numbers to.. I want to play around with rockers on both exhaust and intake.. I have a Desk top Dyno figure I want to see on dyno.. GTO Geoff will love this...he knows what I mean...I'm sure..
Damn, you really stepped things up a "notch", can't wait for the dyno numbers! I love seeing what these "little" "D" port heads can do!......Cliff
PS: I hope you've got good brakes on that old car, gonna be interesting trying to stop 2 tons at 130mph!!!
Troy,
How wide are your ports. My Kre dports are the 340 cfm version and they look to be the same height as yours. I have to get a measurement of my heads width. Robert
67 Firebird 467 cubic inches 7.71 @ 92 in the 1/8 and 11.69 @ 115 in the 1/4. |
REALLY NICE 60 MAN CANT WAIT TO SEE #S
Hey Troy,
Motor looks great, That Jack can really put a motor together. I can't wait to see those numbers also. Good luck with the new mill, hope to see it run this year. Mark P.S. If that motor turns out to be tooooo much for you, I will trade you my Jack motor for yours
1965 GTO: 467 (Built By Dan Willever), 400 Block, Eagle 4.25 Stroke, Eagle 6.8 Rods, BRC Pistons, Custom Grind Hydraulic Roller Cam, Edelbrock 72cc Heads Ported, HS Rockers, Doug's Headers, Edelbrock Victor 4150, QTF 850 Carb, AutoGear M22 4 Speed, SPEC Clutch and Pressure Plate, 12 Bolt 3:73 Posi. |
Sheesh, those casters on that engine dolly look like they're ready to bite it!
Nice motor by the way!
1969 GTO Judge Ram Air III 1968 Catalina "Darkside" Vert! |
Nice combo Troy, Hope your chassis can hold it. Dave Johnson
Hey Cliff. I can't wait to see what these poor old "little" D ports do either.
Hopefuly enough to Keep on truckin'... Got to keep these Ventura's rockin' I hate to part with 8 lugs but I also have a Scarebird front disc conversion setting on the shelf. It's not the 1/4 mile tracks that get me...it's those short little 1/8 mile tracks with even shorter shut downs... Have had to change shorts all ready a few times....Quick67: I think port width is 1.50 or 1.55. I really don't know the port cc's....Just haven't bothered.. I'm with you 10second70GP..####'s please Hee-hee..thanks Mark..think 60 will be fine with 505.. Chris:..Yep the casters are "Roached".... Dave...I've made a few "small" changes to suspension and beefed drive train. Hope it will hold until I figure what I want to do.. Maybe at least you won't blow my butt away to bad at Norwalk... Steve C.- Just barely made it back from Tenn. without being assignated..
Reportably the KRE 325 cfm D-ports have about 215-220 cc intake runner volume. With that big cam it will be interesting to see where the motor makes it's peak power at. Any hints from the computer program ?
With a shorter 4.125 stroke the 482 using the Edelbrock heads at a 234 cc runner volume made its peak power at 6900 rpm with a 279 at .050/.704 lift solid roller. With the new revised combo and using the bigger High-Port heads John's motor made it's peak power at a lower 7000/7100 rpm with a 285 at .050 /.850 lift roller. (I'm trying to keep my new street 505 under 6000 rpm. Should dyno next week) Last edited by Steve C.; 03-23-2007 at 11:29 PM. |
I think Steve meant 215-220cc for the ported KRE heads. Definitely to big for a tractor motor
Thanks Skip, I corrected it. big differance and big impact on results.
I got those numbers from a discussion about a set of KRE D-ports that were about 323 cfm at .600 lift. Jeff confirmed it. In contrast Bob Davis KRE ported 310 cfm @ .600 head Edelbrock heads have a 236cc runner (SCE 128105 gasket/ 2.3 ports ) Big inches + big roller + small runner volume heads Last edited by Steve C.; 03-23-2007 at 11:46 PM. |
