Old 08-03-2007, 03:15 PM
Whse 1 Whse 1 is offline
Default Grounds
Where are the ground straps attached on a67 GTO? Ithink there are three?
Old 08-03-2007, 04:00 PM
6704gto's Avatar
6704gto 6704gto is offline
one to the firewall and frame,i think the second is from the engine to the frame
Old 08-03-2007, 04:46 PM
YVEYANT's Avatar
YVEYANT YVEYANT is offline
Send a message via AIM to YVEYANT
One from the passenger fender to the frame (small one)
One from the coil to I think the block (does not really matter as long as it is grounded) (meduim size) don't use this one if you have HEI with a distributor top mounted coil obviously
One from the firewall to the back of the passenger side head (large one)
Ant
1967 Pontiac Tempest, GTO-Inspired
"What's so special about having Italian food cooked by a bunch of friggin Mexicans"
Paulie-
Rocky Balboa
"Your heart is free, have the courage to follow it"
Braveheart
http://i106.photobucket.com/albums/m...Wm0SlqN030.jpg
Old 08-06-2007, 07:08 AM
Default Grounds
Thanks Guys
Old 08-06-2007, 07:14 AM
Default grounds
Thanks Guys
Old 08-06-2007, 08:38 AM
Brad B. Hillebrand's Avatar
Brad B. Hillebrand Brad B. Hillebrand is offline
One VERY important thing to do is use "Dielectric Grease" on those connections, all electrical connections. The grease stops corrosion and enables the connection to stay good. Also, you need to remove paint to get good metal contact. Put the grease on the bare metal and rub on the connector as well - make it nice and tight and you won't have to worry about it again....
Old 08-06-2007, 09:39 PM
ron cozzo's Avatar
ron cozzo ron cozzo is offline
Close, but not quite.
1) Passengers inner fender to frame, near the front.
2) Coil bracket to firewall, this is on the passenger's side.
3) Rear of Driver's side head to firewall.
'04 GTO Yellow Jacket, A4, Kooks, CAI, etc.
'02 Firebird, V6, auto
'68 GTO Convertible, HO, 4spd, driver
'66 LeMans Hardtop, 400, FI, A/C, 4L80E.
'65 GTO Hardtop, next project
'64 GTO Hardtop, "389", Tri-power, 5 speed, A/C, Yorktown Blue.
http://www.gtoaco.com
