I have a 2000 Grand prix 3.8 gt. It only has 62k. It surges up hills. or when accelerating lightly. I dont want to throw parts at it. It has no codes. Has anyone else had this problem? I did a search without much luck. Thanks
I would start with the fuel pressure regulator. There is a method to test them on the car, but I am vague on the procedure. Not greatly difficult, though.
Some other members may have the know how on testing. |
Is their no codes lit or just no check engine light, I had to take my car to a place that can read the memory as their were no check engline light on to test with one of those testers that advance ( work part time their) or autozone has. It pointed to the mass air flow sensor and the car had a similar problem but the Mrs called it a jump. It has resolved the issue by replacing the sensor.
74 Formula Below motor destroyed last fall 469, 6X-4's, 72 Intake, Ramair Manifolds. 3 inch exhaust with x-pipe Custom Roller Cam, 1.52 Roller Rockers Quadrajet done by Cliff 3:42 gears 12.061 @ 110.74 12.092 @ 112.43 12.128 @ 111.71 New motor 461 stroker Edelbrock 87 cc dport heads Performer RPM Same Ram Air manifolds, and quadrajet Results will be posted after the track |
