Old 11-09-2008, 07:46 PM
Tinindian6702's Avatar
Tinindian6702 Tinindian6702 is offline
Default stock 10 bolt rear question
I currently have my rear axle out and on the bench for cleaning and painting. I am about to put the 10bolt cover and gasket on. Is there any reason I can't add the oil to the case before I close it up??? It would be easier than adding it through the small hole. The only thing is that I don't know how much to put in. Where would I find the capacity? It is a stock rear. 67 firebird. Thank you
1967 400 Firebird Convertible :
1978 Firebird Esprit
1980 Trans Am Pace Car (SOLD)
2002 RamAir Convertible
Old 11-09-2008, 09:00 PM
limejudge69's Avatar
My capacities chart says the rear holds 4.5 pints, or 2.25 quarts.
Old 11-09-2008, 10:10 PM
Stuckinda60s Stuckinda60s is offline
The way I would do is to put the rear up on two jack-stands with the yoke down and the axles inserted and the retainers bolted up. Add the required amount, put the cover and gasket on, tighten them down and then rotate it until you can support the case with the yoke at a slight downward angle. Next spin an axle a couple of times to distribute the oil, let it sit for a few minutes to level out, pull the plug and make sure the oil's at the bottom of the hole. If it's higher you can drain it until it's at the proper level.
Rich
The real democratic American idea is, not that every man shall be on a level with every other man, but that every man shall have liberty to be what God made him, without hindrance.
Henry Ward Beecher
"The problem with socialism is that you eventually run out of other people's money." Margaret Thatcher
Old 11-10-2008, 07:23 PM
Thanks guys.. I was trying to avoid taking the plug out and dribbling on my new paint job.
