I need a throttle cable bracket that fits on a 1969 intake manifold.
I have one part #9792068 but it does not align with the last intake bolt and the boss on top of the manifold. Does anyone have one? Thanks Keith |
You have a bracket for a 1968-69 2bar.Bracket listed for a 4bar is 9792069.Unfortunately I do not have what you need.
Don't know if this will work, but I have the bracket (9787161) that I took off my 66 LeMans. Cable came through the firewall and mounts to bracket.
I have a very nice throttle cable braket from my '69 Judge 4234 intake. There is no part# stamped on it but it fits perfectly. May be aftermarket. I found a numbered one for my restoration so this one is good to go.
The correct bracket for '69 should be stamped T-4 same as the one below.
The one I have has T4 stamped on it like this one. My original has the GM part number 9792069 stamped on it. Both will work. Most of the aftermarket ones now have the GM
number stamped on them. |
