Old 08-31-2009, 04:52 PM
maciek's Avatar
maciek maciek is offline
Default Lemans 1979
Hi i am new on this forum and i have question i have a problem water is cumming inside car on passenger side between firewall and dashboard did some one had that kind of problem ?
Old 08-31-2009, 05:32 PM
DiamondJim's Avatar
DiamondJim DiamondJim is offline
Heater core leaking? -Jim
Old 08-31-2009, 09:26 PM
Pontiacmuscle's Avatar
Pontiacmuscle Pontiacmuscle is offline
Send a message via Yahoo to Pontiacmuscle
Ding Ding Ding!! Tell Him What We Have For Him Johnny! Jim nails it! Welcome Maciek!
ARROWHEAD ADDICTION: An incureable disease contracted from the pointed edge of classic pontiacmuscle; all consuming, taking over mind, body and soul.
Old 09-01-2009, 12:53 AM
maciek's Avatar
It leaking only when it's rain outside, I cannot find from where it's leaking.
Old 09-01-2009, 01:20 AM
Pontiacdaver's Avatar
Pontiacdaver Pontiacdaver is offline
It is your windshield seal, it has dried out or rusted in the channel that holds the windshield. To fix it right, you will need to remove the chrome molding around the windshield, removed the glass, clean the channel it sits in, and see if there is rust there. If you haven't done this sort of thing, you might want to have a professional glass shop do it for you.
Dave
2 wrongs don't make a right, 3 lefts do. 4 lefts make a NASCAR race but who cares?
2004 Grand Prix GT daily driver
1974 LeMans GT 455
Old 09-01-2009, 08:09 AM
A important piece of diagnostic info ) Dave is correct I believe...I've had this happen on 2 or 3 cars..most good glass shops in your area will take the extra time to do what you need as well.
Old 09-03-2009, 10:13 AM
srercrcr's Avatar
srercrcr srercrcr is offline
Damn, I thought that leak came standard from the factory!
Welcome Maciek.
Old 09-03-2009, 03:37 PM
PMDJIM's Avatar
PMDJIM PMDJIM is offline
Check for the water leak with a garden hose. Start at the cowl and slowly work your way up the pillar until you see the water comming in. Another way is with compressed air and soapy water. Spray soapy water on pillar or winshield. Apply low pressure to the inside of the windshield. Watch for bubbles on the outside.
Old 10-18-2009, 03:40 AM
elcaminobill's Avatar
elcaminobill elcaminobill is offline
My Lemans had a water leak around the heat/AC blower fan. It took me while to find it but after sealing it up with black silicone the leak stopped. One thing I found that you may want to look at: The cowl has a flapper valve at the bottom to let water escape. The valve has a tendency to get clogged up with leaves/ debri. Remove the cowl grill reach down to the bottom front end of the cowl to find the valve.
