Old 11-09-2009, 02:58 AM
70FormulaCA's Avatar
70FormulaCA 70FormulaCA is offline
Default 70 Radiator and shroud - original?
Need some help identifying if my radiator and fan shroud are original that are from my 1970 Formula.
What should I look for? I noticed the radiator has a metal tag with codes attached to the pass. side of the radiator about half way down.
Any help is appreciated. Thanks!
Old 11-09-2009, 08:27 AM
GETRIDAONE's Avatar
GETRIDAONE GETRIDAONE is offline
The reproduction shroud is open on the bottom and has a square 1/2" hole on the top of passenger side. I'm not sure if there is a part number on OEM's anywhere. I think the tanks on Harrison raditors are a little unique but I don't know how to identify one. Maybe someone with more cooling knowledge will respond.
Name:	70 RADIATOR CHART.jpg
Old 11-09-2009, 10:59 AM
Norwood's Avatar
Norwood Norwood is offline
Not a reproduction...But a later GM replacment. Still avalible I think.....
Old 11-09-2009, 03:57 PM
RAFormulas's Avatar
RAFormulas RAFormulas is offline
Yes, they are still available from GM.
But for those of you thinking of buying one... DON'T, the GM replacement is easy to spot as a non-original part.
Steve
1970 Formula 400 (YS) M40 (67-Castillian Bronze / 215-Deluxe Medium Saddle)
1970 Formula 400 (WT) M20 (67-Castillian Bronze / 213-Deluxe Dark Brown)
1970 Ram Air III Formula 400 (YZ) M40 (26-Lucerne Blue / 201-Standard Medium Bright Blue)
1970 Ram Air III Formula 400 (YZ) M40 (26-Lucerne Blue / 211-Deluxe Medium Bright Blue) *SOLD*
Old 11-09-2009, 09:28 AM
If the radiator is still wearing that tag, chances are its original.
Look for the two most prominent letters on the tag (the two smaller sets of letters identify the end tank codes... the larger two letters the entire radiator), and look for a match with the chart GETRIDAONE posted.
Old 11-09-2009, 04:57 PM
RicksGTO's Avatar
RicksGTO RicksGTO is offline
my '72's shroud doesn't have the square hole in the upper passenger side so it leads me to believe it's an original shroud but I'm not sure I know what is meant by the reproduction shrouds being open at the bottom. Here is a pic of it off the car if someone can say if it's an original shroud or not, I would assume the '70 shrouds would be basically the same as for my year:
'72 Formula 455HO TH400, Revere Silver, black deluxe
'74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe
Old 11-09-2009, 05:28 PM
That is a original . On the gm replacement ( don't call it a repro ) the bottom 1/3 of the round opening is cut out about 1'' into it .Some one should post a picture soon .
Old 11-09-2009, 05:46 PM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
Yep - yours is an original shroud, Rick.
Sorry, but I don't have a pic of the GM replacement shroud.
Regards,
"455HO" Lloyd
Old 11-09-2009, 07:16 PM
Norwood's Avatar
RicksGTO, did you refinish that or is that the original finish? It looks very nice..
Old 11-09-2009, 08:27 PM
RicksGTO's Avatar
thanks, I stripped the paint off of it and used the SEM landua black again, good to know its an original shroud too. Kind of like the GTO shroud's in '69-'72, the GM replacements all have a missing chunk on the driver's corner from a bad mold so they just keep making them with the flaw.
Old 11-10-2009, 02:26 AM
Yes, it's a very nice finish. Did you have to scuff/sand it before spraying the SEM paint? Did you use primer?
Based on the replies and the picture you provided, my shroud appears to be original but just not as nice looking as yours at the moment!
Old 11-10-2009, 08:00 AM
GETRIDAONE's Avatar
Poor picture of "GM replacement" shroud with cut out at bottom. The finish on the replacement is very poor. I thought when I looked at one, my almost 40 year old one looked as good or better with just a good cleaning. SEM products will do wonders on old plastic items.
Old 11-10-2009, 04:05 PM
RicksGTO's Avatar
I started with easy-off and then used 00 steel wool soaked with paint thinner to get it back to bare plastic all over. I used Bulldog adhesion promoter all over it as a primer and then a few light coats of SEM landau black
Old 11-10-2009, 08:21 AM
Norwood's Avatar
I am positive that there is a filler panel that goes in that cut out....Anybody have a pic ?
Old 11-10-2009, 09:06 AM
The codes on the radiator tanks themselves are CV on the passenger side for a 4 speed 4 core ( ram air car ) and IF on the driver side of the same radiator . These are the important codes to look for as the tags are reproed and easily replaced . You can also look inside the radiator at the cap opening to see if its a 4 core but the codes on the side of tank facing to the rear are the most important identifications .
Old 11-11-2009, 03:11 AM
So I went out to the garage and checked the radiator for the codes. I found the IF pretty quickly and the CV was a little harder to spot as it was a flatter marking compared to the IF code. Also, here's what the metal tag reads:
IF FP
CV
91 (or 81 not sure)
Do these codes mean anything?
Old 11-11-2009, 11:08 AM
IF FP
CV
91 (or 81 not sure)
Looks like you got the correct radiator . Those codes mean your lucky .
Old 11-12-2009, 02:49 AM
Were 4 core radiators only available with the ram air cars? Or was the 4 core just the heavy duty radiator option that could be ordered with any Formula/Firebird?
Old 11-12-2009, 09:29 PM
See the chart Getridaone posted above. FP radiators came with all manual trans cars that were equipped with HD radiator option (typically all cars with 3.73 gears), and all manual trans cars that had A/C (even a base Firebird).
But you won't find many FP radiators still around, that's for sure.
Old 11-12-2009, 07:09 AM
Norwood's Avatar
Loyd, I like that Formy...someday I'm gonna get me one of those....
