Old 07-15-2011, 04:45 PM
phk1967 phk1967 is offline
Default Installing an fm converter?
Does someone know how to install one? Does the blue wire go to a hot or ground connection and where would be the best place to connect it? The black wires are installed just not sure about the blue one.
Old 07-15-2011, 05:19 PM
Pepi's Avatar
Pepi Pepi is offline
What brand name is it?
1973 Formula 400 4 spd 04C build date Norwood assembly plant.
Old 07-15-2011, 06:19 PM
It's a Tonitron model TC-22
Old 07-15-2011, 08:48 PM
stevep's Avatar
stevep stevep is offline
I'd say that the blue wire goes to a power source (preferably someplace with key-on voltage) and the black wire plugs into the antenna lead of your AM radio. The vehicle's antenna lead gets plugged into the FM converter.
Old 07-16-2011, 01:02 PM
Thanks, I just wanted to make sure,I didn't want to fry the converter.
Old 08-30-2011, 02:47 PM
j69shep j69shep is offline
Blue wire to 12volts switched on source. Make sure to ground the case of the converter to the chassis of your car to provide a ground path. Plug your car antenna cable into the back of the converter and the converter antenna cable into the antenna jack on your AM radio. Most of those converters were made to broadcast FM at about 1400Khz so tune your radio to 1400 and power it up and see if you recieve FM. Use the tuning dial on the converter to select FM stations and keep your AM radio tuned in to about 1400. Good luck and let us know if it works. I have a whole bunch of those converters and they work really well. Regards, Jim
