Old 09-18-2011, 08:09 AM
Sloan66's Avatar
Sloan66 Sloan66 is offline
Default Air Compressor Size
What size of air compressor do you need to handle painting a car? Who makes a good one reasonably priced? Thx
Old 09-18-2011, 08:52 AM
uforacing's Avatar
uforacing uforacing is offline
The bigger the better. I have not bought one for 25 years so others would have to chime in. Just paint is one thing but I take it you also want to run a DA and other tools as well.
This is one area that I firmly believe in not to try and be cheap. Buy a good one and for most of us backyard painters it will be your last one.
72 GTO 400-M20 Lucy Blue
86 2+2 Black
09 G8 GT red
08 Torrent GXP (wife's)
09 G8 ST (UTE) black
A pissed off fat house chimp on dope would be a lot more deadly.
Old 09-18-2011, 05:00 PM
shawn e.'s Avatar
shawn e. shawn e. is offline
I have a 60 Gal. and that is pushing the limit for painting. I have to give it lots of "Rest" when running my DA.
Shawn
"Don't let fatigue make a coward of you."
Old 09-18-2011, 05:28 PM
jetallman's Avatar
jetallman jetallman is offline
I have a 80 gallon 71/2 hp eaton has alot of bells and whistles and a 5 year warrenty, the best part is the cfm it puts out, i needed 32 for my blast cabinet and it works just fine. cost about $1300 and another $140 by using my own shipping company, got it the next day they shipped it
69 455/4-sp windward blue under major restoration
69 400/400 waiting for resto
Old 09-18-2011, 06:44 PM
6t7goat 6t7goat is offline
I have an 80 gal lowes model I picked up on Craigslist for 325. It was barely used. It did a good job when I painted my car and have no problem with it keeping up with my DA and other air tools. I had a 26 gal husky before this one and it could not keep up and was way too small to keep up with my DA and paint guns
Old 09-18-2011, 06:52 PM
jetallman's Avatar
The Lowes compressors usually only have 12-17 cfm that is why it dont keep up, it cant make enough air. I run a pressure pot blast cabinet, da and every other air tool without ever having to wait for it to catch up. (not at the same time) and with the free run it never shuts on and off it just free cycles until more air is needed
Old 09-18-2011, 08:35 PM
carcrazy carcrazy is offline
You can usually paint a car with a 60 gallon unit (I've done it many times). I have a Lowes unit rated at 13.4 scfm at 40. However, keep in mind that air requriements can vary significantly between spray guns. Some are real hogs!! If I had to do it over again I would have gotten a slightly larger unit. There are some really good posts on this subject in the archives.
Old 09-19-2011, 07:09 AM
PontGuy's Avatar
PontGuy PontGuy is offline
Figure on 220V electrical hookup in order to get enough HP to make enough CFM. Walking through local stores they are selling a lot of compressors with big tanks but very small compressor heads. Not good for continuous-duty high CFM work like bodywork and painting a car.
1969 Lemans vert, matador red, 462 CI, 3.07 12-bolt posi
1974 455 TA, admiralty blue/red interior HPP "cover car" - sold
"The best way to show a car is to drive it"
Old 09-19-2011, 07:35 AM
dhutton dhutton is offline
5 hp, 80 gallon, 220 volt. Anything less and you will likley regret it.
Don
Old 09-19-2011, 08:07 AM
60man's Avatar
60man 60man is offline
60,80, or 120 gallon tanks are all fine for storage capicity but you need to match the compressor head output to your tool demand ...if you don't you will always run out of air at some point. Most modern paint guns (LVP) don't require a lot scfm to paint. Sanders & die grinders chew up a lot of air..Depends on what you want to spend $$$$... I make do with my 80 gal. mid priced compressor.
If you do away with "dead end" air lines and use a loop system you can get a lot more air...almost double the volume...
JMO...&...
ECM member.
2008 Outlaw Pontiac Drag Series Champion
MANDRA
Do it now fool! Life is short.
69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'.
Going back to track with pump gas engine....
My 60 Ventura retired to street/strip duty..
Old 09-19-2011, 09:04 AM
2002Z4CSS's Avatar
I used to paint cars with a 20 gallon Craftsman compressor that was 220v. It ran all of the time when painting a car. I got a 60 gallon made in USA up right compressor with 6hp motor and it does not run as much when painting a car and there fore I get less condensation too from the compressor heat.
1971 Pontiac GT-37
Old 09-30-2011, 08:05 PM
68GTOSCA 68GTOSCA is offline
Gentlemen:
I under the impression that it takes 5 AMPS at 220 volt to produce 1 HP. Thus, it will require 25 AMPS at 220 volts to run a 5 HP pump. Am I right or does someone see it differently.
Thanks In Advance
Sean
Old 09-30-2011, 09:17 PM
mrennie's Avatar
mrennie mrennie is offline
I would agree with that, but only if the supply voltage is really 220V. Isn't it really more like 240V? (it is here in Ontario)
1HP=768W
However, most single phase motors are only ~70% efficient, so taking that into account:
768W / .7 =1097W
1097W / 220V =4.99A
If the supply is actually 240V then draw per HP is actually 4.6A
I have a 7.5HP 80 gallon compressor and it draws 37A while running, which works out to be 4.93A/HP.
Michael
1970 Oshawa built 1 option Judge. 24 year restoration/upgrade project finally finished!
1979 Trans Am - low-buck drag car project for when I retire
