Old 09-07-2012, 11:38 PM
Andy65GTO's Avatar
Andy65GTO Andy65GTO is offline
Default 389 Engine paint flaking off near exhaust manifold.
Does anyone know how to get around the problem of flaking paint and rust on the 389 block near the exhaust manifolds and on the intake near the carbie? Any information would be appreciated,Thanks.
Old 09-08-2012, 02:02 AM
I've used red oxside primer before I painted the heads but they have to be comlpetly clean, but the center exhaust ports will always burn off the paint to some degree. It gets extra hot there because of the 2 ports together. Almost no way to stop it except not to start the engine. I'd go talk to a powder coater to see it they have anything that will not burn off, but I don't know of any sure way to stop some burn off.
Old 09-08-2012, 02:53 AM
Thumpin455_GTO's Avatar
Thumpin455_GTO Thumpin455_GTO is offline
Im working on something, will let you know if it works.
Old 09-08-2012, 02:05 PM
ks gto (Cap) ks gto (Cap) is offline
I'm interested also, let us know.
1964 Gulfstream Aqua GTO - 389 Tripower 4 speed - Torq Thrust II's - Cowl hood
1965 Starlight Black GTO - "Wilhite" stroked 421 Tripower - 4 speed - Custom sound system - Frame off
2009 Mysterious (Black) Solstice GXP Coupe-5 speed
Cap & Robin Proffitt-GTOAA PR & Member Recruitment Team
Old 09-08-2012, 11:22 AM
Sloan66's Avatar
Sloan66 Sloan66 is offline
Not sure about the exhaust ports, but I had success with the intake. I used stainless steel shim stock and blocked the heat cross overs. I have a 66 tri power and my choke still works fine and the paint is not burning!
Old 01-08-2013, 11:48 AM
ddella22 ddella22 is offline
I paint the exhaust ports on the heads with high temp exhaust paint and the rest of the heads with normal engine paint, same with the exhaust crossover on the intake,
Old 01-08-2013, 01:49 PM
rohrt rohrt is offline
I used the KBS high temp paint followed by the Bill Hirsch paint.
It does work pretty well. The blue will burn off and leave a gray/silver instead of rust.
