Old 03-04-2013, 08:28 PM
Felix C's Avatar
Felix C Felix C is offline
Default Valve event calculator for Pontiac Engines?
Is there an Excel based valve event calculator for Pontiac engines? You know, plug in your block and reciprocating assembly information for S/D compression values and also customize duration, LSA/ICL for desired valve events and overlap.
Old 03-04-2013, 08:39 PM
johnta1 johnta1 is online now
Not sure what you are wanting?
Dyno type program?
Or just some calcs?
Look here for some calculators that may work for you:
Calculators
Old 03-04-2013, 08:55 PM
Felix C's Avatar
Many Thanks. Great stuff in that link.
Have been using the below for VEs. Another full page one for different compression.(too large to copy/paste) Of course, formulas are lost in pasting into non-Excel. It is a linked formula which demos changes in outputs when relevant inputs are changed. Obtained from stickies section of LS1tech.com so the compression section is LS1 specific. Wondering if there was a Pontiac version.
Inputs lobe specific 0.006 0.050 0.200
Intake Duration - ID 285 222 157
Exhaust Duration - ED 281 226 153
Lobe Center Angle - LCA LSA 112 115 112
Intake Centerline - ICL 108 112 108
outputs:
Intake Valve opens - IVO 34.5 -1 -29.5 BTDC (- indicates ATDC)
Intake Valve closes - IVC 70.5 43 6.5 ABDC
Exhaust Valve Opens - EVO 76.5 51 12.5 BBDC
Exhaust Valve Closes - EVC 24.5 -5 -39.5 ATDC (- indicates BTDC)
Exhaust Centerline - ECL 116 118 116
Overlap 59 -6 -69 degrees
Old 03-05-2013, 08:57 AM
This one may work for you?
Cam Calc
And this one:
Overlap/Lobe Separation
Old 03-05-2013, 09:45 AM
Steve C. Steve C. is offline
The calculator on this site will give you timing events in conjunction with the cam specs.
http://cochise.uia.net/pkelley2/DynamicCR.html
Old information here:
