I had a sewer drain pipe issue that caused me to have to uncover a section of my foundation on Monday. In that section of foundation was my water supply line to the house. It will be at least Sunday before I can get the pipe reburied and right now we are experiencing some of the coldest weather we ever see down here in Alabama. On Monday when I did my digging it was a balmy 65 degrees. Chamber of Commerce type day. This morning it dropped to 15 and Friday morning they are discussing single digits. Yesterday afternoon the plan was to build a fabric tent over the water pipe and stick a shop light with a 60 watt bulb under it to keep the water happy...just let the bulb burn until it either warmed up or I could get the pipe back underground. I get home last night and get one of my shop lights out....it has a CFL in it. hmmmm. So I go to my stash of extra light bulbs and each and every one of them was a CFL. HMMMMM. I go upstairs and everything is a compact fluorescent. Finally, in an old lamp in the basement I found a 60 watt incandescent bulb.
It worked. Old school baby. Heat.
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. ![]() |
The Following User Says Thank You to David Jones For This Useful Post: | ||
As of Jan 1st 2014 you can no longer purchase 100 watt bulbs at retail locations per your friendly EPA and government. Signed back in 07'. 60's and 40' will be gone by 2016 ending the 100 year love affair with the trusty incandescent light bulb.
Thank a "greenie" by punching it in the jewels.
![]() 69 OHC ZH Sprint Hurst 3 Speed 3:55 (1 of 213) 99 Valkyrie 1520cc Flat 6 108hp/110tq - For Sale http://sohcsix.yuku.com/forums/1/OHC-lounge Wanted: 1969 OHC "H" Camshaft |
The Following 3 Users Say Thank You to PMD1969 For This Useful Post: | ||
![]() Quote:
Since the bill to eliminate them was signed in 2007 I've been hording bulbs of all wattage's. I've got literally thousands of bulbs sitting on pallets in my basement. Black market, eBay lightbulb business here I come! David brings up a great point regarding incandescent lightbulbs. That is, 80% of the energy they use is given up as heat. While at first this seems like a waste of energy, just know that the lack of this heat in someone's home during the winter months will have to be made up by the central heating system.
John ![]() "There are no stupid questions, but there are a LOT of inquisitive idiots!" |
The Following User Says Thank You to johnsma22 For This Useful Post: | ||
![]() Quote:
My daughter is a lighting consultant for one of the larger lighting dealers in Madison, WI. In the "old" days of all incandescent lighting - that showroom was almost unbearable on a hot day. The AC system was running overtime and couldn't keep up with the heat produced by an entire showroom with the lights on. _____________________________________ Back to the "preventing pipes from freezing" topic.... Two inch thick styrofoam insulation would work better than hay - and for most people is more readily available (any Lowes, Home Depot, etc). You could use a can of spray foam insulation to seal the edges if there were any significant gaps. |
![]() Quote:
![]() Quote:
If you cant drive from gas pump to gas pump across the map, its not a street car. http://s207.photobucket.com/albums/b...hop/?start=100 |
![]() Quote:
![]() Quote:
Idea: Knowing you're still in the healing recovery mode, weather roller coaster, etc. if you can't get it covered you might get a "Heat Tape" from an RV or Home supply co. Not certain if used in your area - in case you don't know heat tapes are: often used on pipes under RVs & Mfg Homes to prevent freezing. Simple plug into same extension cord you are using now for the Heat Tape. Similar to "Block Heaters" for vehicles. |
Next time grab a bail of hay and a piece of plastic. Break open the bail of hay and sprinkle it liberally in your hole, cover the hole with plastic and put rocks on the plastic to hold it in place. Will work a whole lot better than a bulb.
Some guys they just give up living And start dying little by little, piece by piece, Some guys come home from work and wash up, And go racin' in the street. Bruce Springsteen - Racing In The Street - 1978 |
![]() Quote:
Sounds great Chris. ![]() I had the shop light, bulb and 2 old sheets. I will confess to using a clump of dirt and a piece of rotten limb as ballast to hold the folded sheets in place and an extension cord to transfer electricity to the bulb. Not much call for a bale of hay on my 1/3 of an acre here in Pleasant Grove..... ![]()
You can still buy any incandescent bulb wattage, if it is a "rough service bulb". Loophole.
GoatDr |
The Following User Says Thank You to GoatDr For This Useful Post: | ||
Incan's are not allowed by OSHA to be used in licensed auto shops.
Can they be used in non-auto shops?
They work GREAT in a 20" wide, 5 foot deep trench.
![]() Quote:
Ric |
Great. Now there is a black market for light bulbs....
David, up in the cold weather of Northern NY we lived in a house trailer. The pump for the well was in a 4 foot deep pit with an insulated cover... half of it under the trailer and half out in the cold. Mind you we got temps in the winter that would make you think we lived in Alaska... above the Circle. LOL To keep the water from freezing up in the tank, the pump, and lines, Dad put a 60 watt bulb in a work light in the pit. It kept everything warm enough so none of it froze up.... except when the bulb burnt out. Heating tapes would last a week or so and crap out, That was the reason for the 60 watt bulb coming into play. And it worked. Yer lucky you found one.
![]() By the same token, if your furnace goes out. Several lamps with 100 watt bulbs will heat a room so you can stay warm.. not by much but it helps.
![]() Gary Get in, ShuT Up, Hang On! Member of the Baltimore Built Brotherhood MY GTO built 4th Week of March 1966 "Crusin' Is Not A Crime" Keep yer stick on the ice. |
![]() Quote:
Man, if I didn't live in this crapfest of a masshole state with a 10 round magazine limit, I'd take you up on that! I just picked up a SW MP 15 .22LR and the factory 10 round mags are no place to be found on the planet earth!!!
![]() Quote:
It's automatic for her to turn the lights on when she walks into a room... ![]() |
![]() Quote:
My wife will flip on the TV in the kitchen, along with both sets of lights, stay a few minutes doing something and then walk out of the room leaving everything on. I'll say something about it and she'll go "oh".
