Old 02-05-2014, 06:48 PM
Ram Air IV's Avatar
Ram Air IV Ram Air IV is offline
Default HEI distributor problems ??
I have an original 78 Transam, with the 400 Pontiac engine and every since I have owned this car, it always arcs a pinhole thru the rotor cap,replaced with new factory and MSD caps ,usually good for a few miles then arc thru occurs upon restart. Just want to change the distributor out to something more dependable. Any good luck with the aftermarket ones? Thanks...
Old 02-05-2014, 06:58 PM
MNBob MNBob is offline
Mine is a one owner and the HEI has always worked well. I can't remember the first time I put in a MSD ignition, but you remove the module when you do. I have always used Accel caps.
Where is the pinhole in the cap, on the top? The caps don't seat all that easily, you need to make sure it is all the way down and in the notches.
1979 TATA Extreme TKO .64
Hedman elite; Pypes 2.5; Borla XS; MSD 6A; Edelbrock intake; open scoop; Sniper Q-jet; Powermaster 150; 4 core radiator/Mark VIII fan; RobbMc mini starter; subframe connectors; solid body mounts; fiberglass rear springs; poly sway bar and link bushings; 81 master; D52’s; Blazer disks; 225/60 & 235/60 17's TrueContact's; relays for PW, PDL, lights; keyless entry
Old 02-05-2014, 11:06 PM
Ram Air IV's Avatar
I will try the Accel rotor and the pinhole burn thru is on top of the cap everytime.I also installed the MSD coil and replaced the module with a brand new factory GM one . Thanks...
Old 02-06-2014, 09:34 AM
I think the MSD coil is remote and they use a cap cover. Maybe there is something wrong with this setup. The first thing I would try is a new cap and rotor and the stock in-cap coil and see if it still does it.
I use an Accel in-cap coil. It uses the little button rotor contactor, with the spring, rubber washer, and dielectric grease like the factory coil.
Old 02-06-2014, 03:46 PM
Ram Air IV's Avatar
The MSD coil is the in-cap design and the dielectric grease was applied on the rubber washer ,that fits in the center of the cap. List of "new" items is GM cap,plug wires & module , Accel rotor,Borg Warner pick-up coil . Thanks Bob
Old 02-06-2014, 05:21 PM
I've always used Accel cap and rotor and in cap coil. They a;so have a special coil "button" that is supposed to handle more jiuce than a factory "button".
Old 02-07-2014, 01:09 PM
jonmachota78's Avatar
jonmachota78 jonmachota78 is offline
Yep ^^^^^^^ i too had problems before using the MSD coil button. I think it should be a requirement when running a bug zapper.
'78 Macho T/A DKM#95, 460cid, SRP pistons, KRE 310 D ports,
3" pypes, Hooker 1 3/4" headers, hydraulic roller,
10" Continental, 3.42 gears
11.5 @117.5mph 3900lbs
([_|_] ##\|/##[_|_])
Old 02-06-2014, 05:54 PM
Ben M.'s Avatar
Ben M. Ben M. is offline
What's the plug gap set at? Too high (0.060 or more) will cause what you are describing. I tend to gap my HEI plugs to 0.045-0.050" and no more.
Old 02-06-2014, 06:08 PM
Ram Air IV's Avatar
I will re-gap the plugs @ (.045-.050 ) and give that a try. I have always gapped the plugs @ (.060 )according to GM specs. Always thought that gap was extremely wide for the R-45 TSX and was sceptical about where the high voltage was going bleed off too.Great idea ,Ben
Old 02-06-2014, 07:02 PM
Something is wrong, it shouldn't be doing this. I thought about excessive shaft endplay, but I really don't think it could cause this problem.
This might be one of those issues, where you have to mix and match parts until you find which one is causing the issue. I know it sounds crude, but I can't think of any other way.
Old 02-06-2014, 07:06 PM
Just saw the previous post, with the MSD 6A, I always gap at .060. Still, maybe that does not work with the MSD coil.
Old 02-06-2014, 08:08 PM
gtohurstjudge's Avatar
gtohurstjudge gtohurstjudge is offline
Constant burning thru the rotor on an HEI ignition is generally caused by just
one thing.....a gap between the carbon button in the top of the cap and the metal tang
in the middle of the rotor. Try putting a dab of grease on the metal tang and stick the cap back on, then remove and see if the grease got on the carbon tip. If not, bend the tang up on the rotor until it makes firm contact. The rotor tang acts like a spring and is easily bendable
upward to solve the gap problem. When there is a gap the hot spark on the HEI acts like an arc welder on the distributor rotor. Also, make sure the spring between the bottom of the coil and the carbon tab is pushing the tab as far down as it can travel. If not stretch out the spring until it does.
The Following User Says Thank You to gtohurstjudge For This Useful Post:
Old 02-06-2014, 10:58 PM
highway star's Avatar
highway star highway star is offline
Aftermarket? None better than "Performance Distributors", they make 'em for YOUR application. Really woke up my '78, meanwhile I'll rebuild the OEM.
Old 02-12-2014, 07:08 PM
Ram Air IV's Avatar
Rebuilding the HEI distributor and noticed the felt washer was missing under the pick-up coil or did the 78 Transam have one ? What type of grease is used under the plastic cap in the distributor body well ?
Old 02-15-2014, 11:31 PM
Grand73Am Grand73Am is offline
Here's a previous thread about distributor grease. Looks like it's best to use just plain wheel bearing grease, not the synthetic or disc brake stuff. The plain grease will flow better in this situation. Here's the thread: http://forums.maxperformanceinc.com/...ributor+grease
Steve F.
Old 02-17-2014, 01:31 PM
ta6point6's Avatar
I like Mallory ignitions great product but saw this on MSD site. The other guys are probably right about changing button
The Rotor Bushing supplied is a replacement unit designed for stock or mild HEI Distributors and has very high resistance. If an MSD 7 Series or Digital Series Ignition is used an MSD Low Resistance Rotor Bushing, PN 8412, must be used to prevent damage to the cap and rotor.
going bandit-Reynolds style
