Timeslip from Aug 15..my car is on the left..bit of slippage in the 60 ft...a fellow board member Torquewar's on the right..both great street cars and driven to the track..my last pass I ran 11.59.
Looks like you had some fun with your Poncho. Don't know your combo but that time looks very respectable.
Jim
65 Catalina sedan. Allen Thomas Performance 495. KRE Heads at 310cfm ported by SD Performance, ProSystems Dominator carb on ported Victor intake, P-Dude custom grind hydraulic roller, MSD ignition, 3.50 Moser/Ford rear. F-Glass front bumper by son Rob, rear by the old man and joint effort for trunk lid. 3950# w/driver. Best of 9.5761/139 on 175 shot, 6.01 /114 in 1/8. |
Nice!
'78 Macho T/A DKM#95, 460cid, SRP pistons, KRE 310 D ports, 3" pypes, Hooker 1 3/4" headers, hydraulic roller, 10" Continental, 3.42 gears 11.5 @117.5mph 3900lbs ![]() ([_|_] ##\|/##[_|_]) |
.. darn good considering the 60' ! what kind of weather were you running in??
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile |
Here is the last timeslip..DA's ranged from 2274 early in the night to 1629 near 10pm..This is with a 3.08 gear and a 3900 lb car!
nice.....what kind of tire were you running?...
Mickey Thompson ET Street 275/60/15...just CE 90/10 front CE 50/50 rear shocks nothing else for traction aids..
26" just too small for me.
Nice runs. I love seeing these Pontiac street driven cars lay down runs like that with 3.08 gears and DOT tires!......Cliff
Thanks..even with a Holley it does ok....!
Yep. Not too many Ferds and Chebbies at any track, on any day, that were driven there at 4000 pounds running 11.60`s. Course, most or none at any track would have had 3.08 gears. Even the big blocks would have had 3.73`s.
That`s the danger of Pontiacs on the street.
That thing would run better with a Quadrajet on it....Sorry I couldn't resist, We always hear it the other way around...
What specific carb are you using???
1977 Black Trans Am 180 HP Auto, essentially base model T/A. I'm the original owner, purchased May 7, 1977. Shut it off Shut it off Buddy, I just shut your Prius down...
950hp Holley with a 50 cc pump on front....Torker 2 intake with a 1 inch open spacer.....
A few years ago I switched from the 275/60-15's to the 255's, and they actually hook up better with more air in them than the bigger tires did. I am running them on stock 7" Pontiac Ralley wheels, which does favor the smaller tires as far as how much tread meeting the pavement on the starting line......Cliff
Had a good time with TA man that night. Both cars were hooking good and i finally had a good string of 50s that night. The 47 run was really the icing on the cake.
I wanted to do couple more runs until i lost a alternator belt...` Ernie and myself are always looking to hunt the other brands down with our street cars. Going to head out tomorow night and see if i can get those numbers to improve. TA man cant be there but we have our Pontiac day coming up ,something looking forward too. |
Nice runs guys! Torque!
Darby 74 Grandville 2Dr 455 c.i 4550# 2011 1.60 60 ft,[email protected]@117.74 2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected] M/T 275/60 ET SS Drag Radial 2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's |
What's the deal with listing E.T. at 594 foot? Haven't seen that before.
Mick Batson 1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 Catalina Safari Wagon. |
I believe that is where the beams start for the 1/8mile speed..if you do the math for the 594 and 660 split it works out to the mph for the 1/8th..
very nice that car is running great
hoping to make it to the track with my sons ta before winter last run was [email protected] with 2.56 gear
1980 TA 455 th400 2.56 posi [email protected] http://www.dragtimes.com/Pontiac-Tra...lip-29967.html http://www.youtube.com/watch?v=6X5XJ9PR1Qw https://www.youtube.com/user/hal101/videos Last edited by hal101; 09-01-2014 at 01:19 AM. |
