Old 08-04-2015, 07:12 AM
Chuckgeo's Avatar
Chuckgeo Chuckgeo is offline
Default Turn signal issue
On my 64 GTO, when I turn on the left turn signal the left rear signal and the dash indicator flash but no front left flash. When i turn on the right signal the front and rear right signals flash but the dash indicator doesn't. I've checked the left front bulb and it is good.
Thanks in advance for the help.
Old 08-04-2015, 08:38 AM
Check6 Check6 is offline
I had something very similar in my 66 GTO found out the turn signal wire coming out of the firewall connector was loose. Shimmed it and all is well. Hope this helps.
Thanks,
Fred
Old 08-10-2015, 11:11 AM
killakev's Avatar
killakev killakev is offline
Your flash bulb in the dash maybe burnt out or not making a good connection on the printed circuit board that's mounted behind your gauges. Or worse, there could be a break in the copper trace that sends power to that bulb or the pin connection is poor.
Old 08-11-2015, 07:45 AM
2002Z4CSS's Avatar
Make sure the bulbs have a good ground.
1971 Pontiac GT-37
Old 09-09-2015, 06:54 AM
Chuckgeo's Avatar
Default Update
It was a loose bulkhead connector. After a little wiggling the blinkers and dash indicator all work. thanks for the help.
