Well I learn something new every day. I'm doing the final assembly on my 68 400 engine. I went to put the timing case back on and noticed that I had 3 studs and 3 bolts for the case. It seemed odd to me, so I went out to the man cave and looked at my spare 68 400 engine. It had two studs on top of the case and 4 bolts below the water pump. It looks like the case has also been off of that one, so it could easily be wrong.So, can anyone tell me what is factory correct on a 68 400 engine for timing case fasteners? How many studs and in which timing case holes do they go? I'm assuming then the rest are bolts with washers. Thanks OJ |
The 2 holes below the water pump are for the studs.
Then 2 bolts at the bottom and 2 at top.
Thanks! Does the top bolt with the engine lifting hook get a washer?
I believe so.
I always used one.
There are 2 studs on the LH side for manual steering cars alternator bracket. There is 1 stud of the RH upper for the the loop for an engine hoist hook.
Thanks for the input
If you look in the 68 service manual there are several pictures of 68 blocks with the two long studs installed at the top above the two main water passage in the front of the blocks.
Don't think I've ever seen one with three long studs ... but anything is possible from work done by previous hands over the years. |
![]() I know this is either a 66 or 67 cover, but the studs are in the same place for a 68 cover as well.
1968 Pontiac GTO - Verdoro over Ivy Gold - 400/4-speed/3.08 1987 Pontiac Grand Prix - Sage/Sage/Sage - GM 305/Th200-4r 2004 Pontiac GTO - IBM over Black - LSx 440/6-speed/4.10 SRA - Single Digit Stick Shift |
