Hi guys I could use a little help & guidance. I am buying a '69 and just got my PHS documents in the mail. There was no Car Billing History paperwork - is this common for 69 and above? I am somewhat familiar with 65 and 66 documentation, trying to educate myself on 64 (although that could be offered as a college course with full credits) but I am unfamiliar with 69. Basically just got invoice and power train information. Is there no way to get information on the engine unit number ? Thanks
The EUN is only on the build sheet in 69-up, not on the invoice.
68 GTO Ram Air I Auto, Starlight Black/Teal-Survivor 68 Firebird Ram Air II 4spd, Aegena Blue/Black/Black 68 Firebird 400 Conv. Auto, Red/Parchment/Parchment 69 Firebird Ram Air IV, 4spd Matador Red/Black-Survivor 71 GTO 455HO 4spd, Lucerne Blue/Black/Black 71 GTO 455HO Auto, Lucerne Blue/Sandalwood/Blue |
So if my PHS packet did not come with a build sheet that means it just wasn't available on my particular car for some reason correct ?
It's a Fremont build so it gets a little dicey
The billing history card was saved by PMD as a financial record. That is why they existed abd were available to be acquired by PHS. K
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.56 @ 139 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 |
GTOJohn - just trying to verify if the engine is original to the car. It's a Fremont car with no apparent block VIN. You would think with that great big, beautiful EUN number staring me in the face I could match it up to something.
Keith - the Car Billing History paperwork must have existed in some form or another - any idea why it was not turned over to PHS ? Thanks |
The info they do have wasn't 'turned' over to PHS, I believe.
They were lucking to get what they did I think. What is the engine code, date code and eun on the block and the build date and VIN of the car? I have a database of eun's, might be able to tell if it's close?
As a result, every so often some unfortunate soul will report that PHS does not have the detail for their specific car. Brief history of PHS included below, for your entertainment. These are my own notes; not reviewed or endorsed by PHS. I had the original Pontiac historian, Fred Simmonds, in the passenger seat of my car so I grilled him mercilessly for about two hours. Hopefully the added background will help. K Quote:
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.56 @ 139 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 Last edited by Keith Seymore; 02-15-2016 at 07:52 AM. |
1968 Firebird 400HO convertible 1971 Trans Am 4-speed, white/blue |
My Fremont built 71 had a beautiful one on top of the gas tank. I got lucky that it was in good condition.
For 69-newer all you can get from PHS is the invoice and powertrain sheet. The block will have the vin stamped into it.
For 68-older the Car billing sheet is what you get from PHS with the highlighted order sheets. EUN is available on 67 car billing sheets but nothing older I think. On the 69 you are buying, what are you questioning? |
There were some early '69s that had the Billing History cards. They went to the newer format of invoicing starting in '69. I don't think they saw a need for the EUN to be recorded when they started stamping the partial VIN on the engines. Build sheets typically didn't carry the EUN either. If this car hasn't had the gas tank dropped, the build sheet may still be there.
So the owner is saying there is NO VIN stamped on the engine? I can be pretty faint, but any frame-off should have recorded it if it was there. Sometimes it can be partially obscured by the timing cover.
I'd be very suspect if it wasn't there. SR blocks didn't typically have the VIN if I recall. Here is where they are located .... look down at the lower left in the picture. |
Freemont cars did NOT put he vin there. It's up by the engine code upside down on the passenger side. Look close there. It will be there for sure. |
Well there you go, you can't depend on Pontiac to do the same thing at any two production plants
Wish all the plants put them up there, they would be much easier to read. |
Agree with Ram4king. My YS block from my numbers matching, Fremont-built '69 GTO has the partial VIN stamped way higher than the example in the photo. The stamping is also incredibly faint, so much so that only several of the digits are completely recognizable. If the restorer was a little overzealous with the paint, it could easily be covered up. These 'faint' partial VINs are pretty well known/documented (at least by folks that frequent this board) for Fremont built cars so if you're unable to locate one, the originality argument may still has a leg to stand on. WT was a pretty common block for 69 GTO so there should probably be no more than a 2 month difference in block casting date and vehicle build date. As a side note, I've not been able to locate a build sheet from either the top of the gas tank or behind the rear seat.
Keith:
One was always able to get the 69 and newer invoice by calling Pontiac customer service prior to PHS but they would black out prices. (They always stated 68 and older were not available) Was the post 69 set up differently than pre 69 in Pontiac or was it actually Fred Simmonds pulling each request?
“If you ain't first, you're last” - REESE BOBBY |
I'm not sure why there would be a distinction "pre '69" and "post '69" and can ask Fred the next time I see him. Prices were blocked out because, as mentioned, the documents were maintained as financial records. Since they were still somewhat "contemporary" PMD was apparently still sensitive about cost information getting out into the public. Obviously that is no longer a concern... K
I've got the biggest gap between the block casting date and the car build date that I've ever come across.
Greg Reid Palmetto, Georgia |
james66 recheck the block the Fremont plant stamped the vins much higher than other plants. Many are stamped near the exhaust manifold mount surface several inches from the EUN and YS stamping.
