Front disc Q
A buddy of mine picked an original front disc brake set up, rotors, calipers, master cylinder, backing plates and caliper brackets, the Q is that the calipers are a one piston caliper the guy said it was off a 69 camaro but I'm not sure, the master cylinder is def after market, so is there a way to tell what these brakes came off of so I have a better way of getting parts for these if or when I need? the master cylinder is billit or chrome not really into the look so I would want to get the cast iron master.
These are going on my 67 FB which has power drum/drum Thanks for the help |
pix?
1969 Camaro/1969-72 Chevelle and all A bodies/1969-74 Nova are all same parts.
Now if you're concerned about any matching number kind of stuff I can't help with that. The only difference between the Camaro/Nova and the A body calipers is the hose direction. I can tell you exactly application with a picture of the calipers banjo fitting area. |
ill see if I can get some pics up
Noticed that you're putting this on a 67 so you can't be worried about matching numbers type of stuff. All the D52 calipers interchange, it's the hose configuration that may change. The two that will work out best for your application are the 69-72 A body calipers and the 69 Camaro/Firebird styles. The others will still work but place the hose is a less then optimum position-but still work.
Could you post some photos of what you have?
Ron |
