I have read a bit about it and seen some Youtubes, but have not TT anyone who has actually done it.
If you have, please tell us how it worked |
motorcycle guys like dyna beads, probably take a good bit to balance a tire though.
I picked up a large container of airsoft pellets at a garage sale a while back for $1, figuring I'd try this out sometime. Haven't had an opportunity yet, though.
What would cause round beads to settle both on the side exactly opposite the heavy part of the tire radius or correctly on inner or outer aspect of the tire? Seems to me they will
Just roll around completely useless?? Steve
462 Yc Block, zero deck Probe forged pistons 6cc relief, Scatt Hbeam rods floating pins aprox. 10.21 CR Comp Hyd-roller cam,roller lifters,springs ect. 236 244@ .050 108 LSA .511 lift, duration 289,297 @.oo6 Edelbrock Aluminum 87cc round port heads Larger valves ,ported polished and cut Powerjection3,T2 manifold, Try-y’s Flowcooler water pump. 71 formula with TKO600,hydraulic clutch 3.42 posi and 26 inch tire. 17x9 YO Honeycombs with Nitto 555's |
You don't want to go there with the beads!!,..Myself and other members of our motorcycle
club tried these and they just make a mess of trying to balance at all speeds...Think about it,..your gaining momentum from a standing start and the beads find their inertia on the inside of the tire,thats fine until you slow down or come to a stop, they mix all up again and fall where ever and the beads keeps trying to find their position over and over again!. Once a set speed is going the beads do their adjustment,but a sudden stop or a fast increase again,you feel the imbalance...The beads would be a + at the Bonneville salt flats but not at differential speeds,..of course that was mine and the clubs opinion. PS,.one member had a slow leak in his tires and was finally found that the problem was with these beads had found their way in the rims bead! |
Bluesugar. Thanks for the info!! What your describing makes sense.
Most bikes and some of our cars can accelerate and decelerate very fast so what you describe may be reason to avoid. Is it just HARD accel/decel that creates the issue or would it still be an issue even in something with slow accel/decel like an 18 wheeler? |
Special pellets, with antimatter (don't matter) properties....defy Newton's Laws of Motion.
I don't know if they work or not but I have definitely seen where a lot of people say that they do.
I have heard that the use them, or something similar, in 18-wheeler over the road truck tires??? And I've heard that you're used in tires on lifted trucks, 35 inch Etc. But just because I've heard it, doesn't make it true, and that's why I was hoping somewhere that's actually done it would provide some feedback |
Good reading here: http://http://www.innovativebalancing.com/news.htm
1963 GTO project 1975 LeMans Sport Coupe |
I use beads to balance the 37" MTRs on my F350. In fact, most guys running large tires use beads to balance.
They work OK. It would be easier to tell how well they actually balance if I was running a smoother tire.
"Those poor souls have made the fatal mistake of surrounding us. Now we can fire in any direction" 1970 Trans Am RAIII 4 speed 1971 Trans Am 5.3 LM7 1977 Trans Am W72 Y82 1987 Grand National |
If the Normal balancing procedure is not fixing the problem, there could be:
An internal tire separation Wheel incorrectly mounted on the balancer Balancer needs calibration. Wheel out of round Stiff spot in tire causing a high road force number/variation. Flat spot on tire from a panic stop.
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk |
I have these in the rear tires of my 78 Cutlass race car, 27 X 10.5 - 15 Hoosier Quick Time Pro on 15 X 8 Weld Prostars. No vibrations.
Eric 1969 GTO - 461, turbo 400, Continental 13", 3.08 gears. - 12.59 e.t. @ 108.43 mph, 1.898 60' 1978 Oldsmobile Cutlass Supreme- 461, turbo 350, PTC 3500 converter, 9" 3:50 gears. = 11.39 e.t. @ 117.55 mph, 1.599 60' on E85 |
I have he beads in my '62 Lincoln. The car has 20" rims with 40 profile tires. Dyna beads are not recommended as the sole balancing method for tires with that short of a sidewall. The tires are balanced OK, but still had some vibration. I left the wheel weights on and installed 5 oz of beads per tire. They call this a maintenance amount. They did take out most of the remaining vibration. I'm happy with the improvement they made.
Again, what makes the beads find the light or heavy spot? Answer, nothing. It just dosnt make sense that it would work. There is no correlation between annout of balance situation and beads!??
Unicorn magic LOL. No seriously I don’t get it either
http://www.innovativebalancing.com/HowItWorks.htm |
It seems to defy physics and logic? Oh well, thanks for the link.
I really liked the thing about off roaders telling them how to air down their beaded tyres safely without shooting their eyes out with ceramic bbs. Worth the read just for that.
-- Sam Agnew Where you come from is gone; where you thought you were going to, weren't never there; and where you are ain't no good unless you can get away from it. Ministry - Jesus Built My Hotrod |
Reminds me of the "Tire Balancing Rings" that were sold by Warshawsky & Co.. & JC Whitney Co. in Chicago. I believe JCW is still in business out in Kankakee, IL. Most of you guys are too young to remember this mega-parts catalog house (JCW was the mail order arm of the Warshawsky retail store located on South State Street in Chicago.
The rings were clear plastic tubing that contained steel ball bearings that were supposed to roll into place and effect a correct balance. They snapped onto the inside flange of the wheel much like a trim ring. They were basically useless devices designed to separate the purchaser from his money. |
It's amazing how someone who has never tried them is convinced they don't work.
