SOLD Parts The parts in here have already been sold. The topics will be kept for a few months for reference. |
Chicagoland Area.
$750.00 OBO. Buyer pays shipping from zip code 60047. FedEx & UPS are both shipping options based on buyer preference. A money order is required for payment before shipping unit. This is a two-piece manifold. Intake runner openings measure 2.4 x 1.25. There remains a good amount of intake mounting flange area at the top of the intake to cylinder head mating area. Water cross-over has been separated from intake (I do NOT have the original water cross-over). Having it separated allows for very good alignment of the individual intake manifold ports to cylinder head intake runner openings. The separated water cross-over pictured is from an Edelbrock Victor intake and IS included as it has been slightly modified (clearanced) for this specific intake. The water cross-over has access holes (1/2 for -8 adapters) on the bottom for adding additional cooling lines if desired. Cooling line adapters or plugs are NOT included with the water cross-over. The front access hole of the water cross-over to timing cover has been drilled and tapped and is currently plugged. That specific plug IS included. All studs for the tunnel ram upper piece to lower base are good (no issues). New gaskets for tunnel ram upper piece to lower base ARE included (Mr. Gasket brand). Carburetor mounting studs (where carburetors mount to the tunnel ram upper piece) are NOT included. Carburetor mounting gaskets (where carburetors mount to the tunnel ram upper piece) are NOT included. Intake manifold to cylinder head bolts are NOT included. Unit has been sand blasted, cleaned thoroughly, and painted silver. Separated water cross-over to intake leaves about .250 of space for alignment adjustment (see pic #4 for close-up). The distributor is an MSD 8563 and even with the larger Ford cap there is still .250 of cap-to-intake clearance (see pic #5 for close-up). Last edited by Apache Warrior; 07-02-2020 at 03:02 PM. |
I'll take it. PM sent.
Sale pending.
I KNOW THAT YOU ARE SELLING THE INTAKE TO PONTIACJIM1959 BUT
Could you post a couple of pictures of the intake plenum looking straight down? Also the NASH Intakes were made from magnesium and your intake (like mine) is a Warrior intake but mine never came with a upper plenum. Just for my records as your intake/plenum is in very nice shape. Thanks Tom Vaught
![]() Quote:
I do have a bunch of photos I took at the Tri-Power Nationals of a Nash magnesium intake that was being sold. If these can help at all, let me know and I will dig them up. Jim |
![]() Quote:
1999 WS6 Formula, 1 of 175 1967 GTO Linden Green 4 spd, A/C, survivor 1967 Lemans convt 1967 Firebird 400 bench seat, deluxe interior, auto 1965 GTO 462, KRE unported D-port heads, Bullet 234/244 cam, th400, tight 10" converter, 3.73 gears, 87 octane, 3440 lbs. empty,1.59 60ft, 7.159@95.33 (1/8), a real daily driver, been totaled, rolled 3 times, hit a tree airborne. 1961 Catalina 2 door htp 1960 Ventura 4 door htp wife's car 1960 B'ville 2 door htp 1960 Catalina Wagon wife's car too |
Thanks for the Picture. Possibly one of the early aluminum ones cast up before Warrior Racing put their "WARRIOR" name on the intakes.
I was told BY Doug Nash that HE only HAD the Magnesium Intakes MADE, but what would he know. He has passed on now and can't speak to that question. For a while there were some S&K intakes out there too (between the Nash and the Warrior Intakes). Not sure what the split of those intakes was Mag vs Aluminum. Have you ever seen a S&K Nash Tunnel Ram? Doug Nash, INC is gone and replaced by S&K Tom V.
The plenum should be identical in both cases so if either of you can post them on this thread then I can copy them easily to my Pontiac Parts pictures spreadsheets.
Tom V. Thanks in advance.
Here is what I have. Looks like some mods on the mounting carb bases.
Also have these. They came off the internet, I think Ebay, so pics are smaller.
Looks nicer than mine!
Thanks PontiacJim1959 for the pictures
Hope that helps. I can provide more when I get the tunnel ram if needed. Looks like the top is two (2) two inch carb spacer with a balancing tube connecting the two together. Yes, I know it is cast as 1 piece, but wonder if you could get creative and fab one of these tops up?
Jim, not sure my private messages are making it through...
Shipping via UPS is $60.00. That includes insurance for $750.00. For UPS to insure the shipment, it must be packaged in an authorized shipping box. That is an additional $10.00. Popcorn packing is $5.00 Total for shipping will be $75.00 to your provided zip code. Grand total for MO will be $825.00 and I can ship as soon as I have payment. Thank you, Pat |
![]() Quote:
Probably if you bought a couple of 2 inch open carb spacers and made a balance tube welded between them, you could get close to the Nash upper.
The Nash has a nice radiused lower floor on the plenums so you would want to add that to the bottom of the carb spacers. The Nash manifold openings at the bottom match a Dominator carb gasket and openings. The top matches 660 carb base dimensions. Tom V.
It would be interesting to have numbers of manifolds actually made - Nash/Warrior, magnesium/aluminum. I am sure not many made as there were other manifold choices and I suspect most guys didn't want to cut a hole in the hood of their GTO to fit it. I have only physically seen the magnesium Nash as pictured, and all other Nash/Warrior manifolds have been in photos either magazines or on cars.
Seems to be many opinions on it, whether it is good or bad. I am not looking for maximum performance out of it. I am looking for a period era, late 70's early 80's look that I am building my car up to have. I guess if it really sucks as I have read on a few other forum posts on the internet, then I'll go with Plan B. I remember when the Torker intake was the hot ticket to have. Now it too gets bad reviews. Then there was the Offenhouser line of intakes that were said to be good, and now not so much. Thermoquads and the 3-barrel carbs were supposed to be the ticket as well. So like all things, what works for one guy may not have as favorable a review for the next guy. |
I'm in the "It works!" camp. At least the basic design was good enough for me to build a very successful alky Pontiac 400 for NA mini-pulling, using a Hilborn 4-port on a fabricated plenum on top of it (all fuel going to port nozzles).
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) |
![]() Quote:
66 GTO Nostalgia Super Stock/Street Legal Car 421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99 Multiple NSCA/NMCA World Champion 66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles 67 GTO 2dr Post, 428, Tri Power, 3.55 Gears 80 Trans Am Black SE Y84 W72 WS6 |
I have a Nash and an S-K. I always thought my Nash was aluminum but it could be mag; it is a bit lighter in weight and is dark gray down in the ports where paint didn’t get to it but I’m not 100% sure. Both are as purchased.
