Thermostat Housing Gasket - Which Sealer?
Do you all like using Permatex Ultra Blue, Black, Red or some other type sealant?
Have to buy some and was curious as to what you think is best. |
I use Hylomar on the intake side.Tom
Permatex form a gasket.
Jim Moshier 1971 Grand Prix 462ci SD Performance 6x heads 1962 Catalina 389 1968 Firebird 400-455 I haven't decided "If we ever forget that we're one nation under GOD, then we will be a nation gone under." - Ronald Reagan |
RTV Silicone is for REPLACING a gasket, (used instead of a gasket) not for application onto a gasket. There's a dozen perfectly-good gasket sealers, including but not limited to Gasgacinch, High Tack, Copper Coat, Indian Head, Permatex #1, #2, and #3. Hylomar is top-shelf, but very expensive. "Best"? I don't know. I don't really care. Any of the ones I've listed--and others as well--are entirely adequate. When it's my money, I lean toward Gasgacinch. In the applications that I've actually used 'em on, Gasgacinch does everything Hylomar does, at 1/10 the price. There may be other applications where Hylomar is required--aerospace, for example. |
The Following 2 Users Say Thank You to Schurkey For This Useful Post: | ||
RTV is used all the time on gaskets in various applications. I've personally used Ultra Blue on water pump and timing chain gaskets and Ultra Copper on exhaust manifold gaskets. Great stuff and never an issue!! Stuff says flexible which is a real plus!! To each his own!!! |
The Following User Says Thank You to Ram Air IV Jack For This Useful Post: | ||
...And then I started using REAL gasket sealer, and saw how much better it worked. The gaskets don't squeeze out when the fasteners are tightened, the cleanup when the gaskets are replaced later is easier. And you don't have blue--red--copper--black shiit oozing out from around all the gasketed joints. I see a lot of gaskets stuck down with "Yellow Death", typically 3M Weatherstrip Adhesive but there's other brands of the same stuff, and some guys use "Black Death", same thing, different color. I'll never use that stuff on a gasket again, either. Sticks the gasket really nice. Cleanup the next time is a total bitch. |
I just replaced mine with this new style gasket. Works great, no messy sealer needed.
The Following 2 Users Say Thank You to 69ARROWHEAD For This Useful Post: | ||
I wish more of these types of modern gaskets were available for vintage stuff. They work tremendously. A bit pricey, but often can be used again and again. Reminds me of modern motorcycle gaskets ... they just plain don't leak. It's a safety issue on a bike, not to mention the exposed engines don't market well if they are covered in leaks.
That is for Chevy , similar but not proper . Most use the Chevy gasket & cry about leaks , use the proper Pontiac gasket & have no leaks.
I changed to Hylomar because of the clean up.I found it to be non hardening and WAY more EZ to clean than any other I have used.FWIW,Tom
For ruff surfaces Permatex #3 Aviation works fine.
If the housing is bent you may need a new housing or make it flat. |
The Following User Says Thank You to Kenth For This Useful Post: | ||
Funny story: I was 16, and did some sort of cooling system repair that weekend. 1982 Monday winter morning; driving my 1968 LeMans to High school, and boom antifreeze steam erupts while 1/2 mile from the school.
Rather exciting for me to see the steam cloud. Upper hose blew off the Radiator inlet. Well lesson here: never apply RTV to radiator hose joints. |
The Following User Says Thank You to Half-Inch Stud For This Useful Post: | ||
Never had a problem using permatex ultra black as a gasket dressing....and mostly what I have handy
https://cdn3.evostore.io/documents/f...82180_spec.pdf
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile |
The Following 2 Users Say Thank You to mchell For This Useful Post: | ||
all the other products mentioned will work too but to claim (modern) RTV shouldnt be used on gaskets is not correct... as posted above, permatex says ultra black/grey can be used as a gasket dresser, meaning a light thin coat on both sides, especially for pitted surfaces. |
I drew the same conclusion on my own. Had those junk rubber rear pan seals split and leak. Use cork seal and Ultra Black and it will never leak a drop.
i never had a 3 prong one, used the 5 prong later style on 3 engines that didnt leak... but that older 3 prong one was terrible & not even a professional shop could make it seal, their attempt leaked twice as bad as my initial attempt. finally found the cork gasket procedure & its worked great.
Before you do anything .... lap the bottom of the housing on something very flat. Same with the intake side if you have a block of metal or something to use.
Most used housings have a bend at the bolt hole ears from years of over tightening. Some new ones have less than perfect machining. And I've seen some OEM intakes with pretty rough machining on the gasket surface. |
The Following 2 Users Say Thank You to dataway For This Useful Post: | ||
