Looking for headers that tuck up tight inside the frame rails. My new road racer project car is going to sit pretty low. What's everybody's experience?
I'm not sure what's on the car I bought but the left side tucks up and the right side hangs down way too much. 600-700 hp. Not sure yet whether D-port or round port. Eric
"Everybody has a plan until they get punched in the mouth" noted philosopher Mike Tyson Life begins at the end of your comfort zone. “The mind, once stretched by a new idea, never returns to its original dimensions.” |
I have the 78 on the lift at the shop with the Hookers I can take a picture this weekend.
![]() Quote:
Thanks for your help, Eric
Best to get a custom set made.
The chassis shop 15 minutes from here builds them on the car. Then have to send them to be powder coated.
If you cant drive from gas pump to gas pump across the map, its not a street car. http://s207.photobucket.com/albums/b...hop/?start=100 |
Eric, I had a set of the round port Hookers on my 73 T/A, they aren't going to be the ones you probably want on a corner carver. Mine were bashed and worn on a street car in less than 2000 miles. I'd never consider another set of the round port Hookers for a road race car. The D port Hookers aren't as bad for ground clearance, but still probably not the ultimate in what you're looking for.
I'd be looking at maybe someone that has a set of the Tri Ys used on the forum for maximum ground clearance. If you buy a used set (Tribal Tubes), you won't have to take a lottery chance on paying for the headers, and never getting delivery, "winning the lottery". The other option is custom headers, of course probably the best option, but also the most expensive option......... ![]() |
Dougs tuck up nicely
at least the round port and d port ones i had did i did not try the 2" tube round ports yet but used the 1.75's |
I ran 23.5" road race slicks when I autocrossed the 78 and lowered Guldstrand front springs. I'll check and see if passenger side is lower/higher I think pretty close to the same amount down.
I have a set of dougs and they tuck up pretty good but the flange does hang down a little further than you want on a road racer/autocross car. Buying them in bare metal and modifying the flange is an option. I'm not sure if they make a pontiac headers but STAHL made the headers for my 1969 Camaro Trans Am racer and those tuck 'TIGHT!"
Redline Design |
![]() Quote:
![]() The Doug's sound like the best option for now. I don't mind modifying the flanges Thanks, Eric
Stainless works and Ultimate headers are also local to me and do custom headers but then you're into the $$
Redline Design |
![]() Quote:
i have them on a 2nd gen thats lowered ~2" with a PTFB suspension kit & they do OK with street use like curbs & speed bumps etc & hard cornering/driving on twisty roads. as skip fix mentioned, im sure they'd be ok for auto crossing with relatively smooth tracks, especially if he used them on a lowered car with only 23.5" tires. https://forums.maxperformanceinc.com...d.php?t=848474 |
