Max Flow From 670 Heads?
Saw an ad on marketplace from a guy claiming 670 heads on his 1969 something-or-other Pontiac had been ported to "flow 300 cfm."
My B.S. alarm went off but I started wondering what flow numbers are possible from a 670 head with professional CNC porting?
Mark Las Cruces NM ___________________________ Current Project: '67 Catalina Convertible 400 4-spd |
I think the highest number I’ve seen is 275. And that highest I heard of is 295. But I don’t know if that’s accurate. And neither was a 670.
Sent from my iPhone using Tapatalk |
Marty P had a set of 455 HO heads that were severely ported, several holes in the ports,
(many years ago) and they leaked at 290 cfm. A very accurate flow bench was used. I can believe 275. Tom V.
Without welding or epoxy work a true 270 to 275 cfm@28” is it with a 2.11” valve and a maxed out throat size.
And that 275 number hinges on if the casting has any appreciable core shift! The 670 casting just does not have enough short turn height to make for instance the 285 plus cfm that you can get from all out porting work on all the other D port castings from 1968 to 70. Unrealistically Manipulating the side to side position of a wedge type head like a Pontiac on the bore adapter when doing a flow test can bring in another 5 to 8 intake cfm that will not be had in use when the head is bolted onto the motor with the intake valve up on one side of the bore.
Thanks to all who replied.
Paul C. down in Tucson finished up a set of 7F6's for a 455 I built a while back. They were initially ported by Dan Barton and after Paul was done with them, improving the flow by changing the valve job angles around, they flowed 282 CFM. They didn't appear to be massively ported either, just a very nice job, all done by hand, no CNC program. Paul noted that he flowed several ports and they were all within a couple CFM of each other.
Paul was working on his own set of 670's at the time and experimenting with different things. I don't remember the flow numbers exactly but I remember them being similarly impressive. Not overly difficult to reach these numbers with iron Pontiac heads but it's not cheap. |
Thats the plan after I run my High Port a season or two. Going to see how much power I can make with a 9-1 461. |
Stan
For all you head flow experts, & guys who know how to calculate power related to ET, here's a question.
I assume Randi Lyn Shipp's '67 Bird Stocker runs 670 heads. The car has run quicker than 10.50, on several occasions. So, although the NHRA Stock rules call for no porting, how much head flow is required for that car to run 10.50 ? These old school Stocker combos that can run low 10's & high 9's & are quicker than the same combo was in SS form, back in the '70's, are very interesting to me. I know the unlimited valve spring pressure & cam duration play a big part. But, I don't think that MOST "as cast" factory heads will flow enuff to run the big numbers some are running today. Assume some form of "porting", which would have been illegal back in the old days. Have read all sorts of methods that have been used to increase flow, such as acid porting, inducing rust, & even hand porting, and then covering it up, in various ways, so that it's hard to detect. Assuming that NHRA finally just gave up & decided to let it go. Have read that "Heads-Up" builds some of the very best flowing Stocker heads. There WAS a section on their site, vaguely describing their Stocker head port enlarging modification. But, that section disappeared, as of the last few times I tried to find it. The Stock section just says "Under Construction". https://www.headsupcylinderheads.com...der-heads.html Last edited by ponyakr; 11-25-2021 at 01:50 PM. |
Here’s some info / detail for you folks.
On all of these heads I cover here I am talking about flow numbers that can be and actually still have it be safe to run the heads with water pressure applied to them. If you want to go to completely unsafe paper thin port walls then you can get greater flow numbers out of these heads if your just looking for what amounts to flow bench bragging rights! High comp D port heads of less then 80 CC of chamber volume start life on average with 154 CCs of port volume. If you have a set that has not yet had a valve job that has sunk the intake valve mote then .030”, and if this set of heads has little cord shift then 285 to 290 cfm can be had by very labor intensive porting work. On heads ported like this your raising the the roof so much that your exposing a lot of the rocker stud hole as seen here in my photo of a number 13 casting. Next are the round port 455 HO heads that start life at some 172 CCs of port volume or some 12% larger then the high compression D port heads. All I will say about these heads is that if you are max porting then and you can’t attain the same or greater flow numbers then max ported D port heads then you do not know the proper way and procedures needed to port these 14 degree valve inclination heads properly! Next up the 69 and 70 RA4 heads that show up out of the factory with between 182 to 184 CCs of port volume, or about 18% greater port area then the D port heads . These heads will max port out to well over 325 cfm , but not with out raising up the roof so high at the flange that a high port type Intake is a must. These heads then are better left for most folks being reworked to flow 295 to 300 cfm. I will not talk about the SD 455 heads and there slightly larger port volume then the RA4 heads because there deeper low compression chambers and resultant lower short turn height means that in fully port form they can hardly beat out the potted flow numbers of the ported D port heads! With all of these heads I have covered here that flow over 285 cfm where talking about them having been converted over to 45 degree seats, but still only running a 2.11” Intake valve. In regards to the comment in post number 6 here where it’s stated that it’s not overly difficult to port heads to this level then you need to try hand porting just one D port Intake port into the 280 cfm range, since that’s 3 hours of work to get the port to finish level !!
Wernher Von Braun warned before his retirement from NASA back in 1972, that the next world war would be against the ETs! And he was not talking about 1/8 or 1/4 mile ETs! 1) 1940s 100% silver 4 cup tea server set. Two dry rotted 14 x 10 Micky Thompson slicks. 1) un-mailed in gift coupon from a 1972 box of corn flakes. Two pairs of brown leather flip flops, never seen more then 2 mph. Education is what your left with once you forget things! Last edited by steve25; 11-25-2021 at 07:41 AM. |
Is that better Steve? Geez I figured that went without saying The time involved also goes along the same lines as being pretty expensive, which is what I meant, I thought people could figure that out, LOL In other words I try to give these guys around here a little more credit without the need to spell everything out. |
Good info Steve25 but that seems like out dated information. Accurate to a point but a lot of those "max" numbers have been surpassed.
You rally can’t answer the question as to how much hp is being made to run a 10.5 ET, you have to look at MPH.
In these these types of racing classes the motors are set up to make there best power, but in a very narrow rpm band. The cars are then geared to run in that narrow band which allows the most average power to be used throughout the run, and also every spec of power is applied to the track! The last time I messed around with the intake valve job on a stock 670 head I got it to flow 225 to 228 cfm@28”. If you go by the 225 cfm number then a motor could make 57.8 hp per cylinder at 100 percent VE. This would come to 463 hp out of 8 cylinders. In a 3500 lb car this will go 11.3 to near 11 flat in the 1/4 mile at about 120 mph. And increase of VE by just 5 percent gets you to 485 hp, and now your darn close to running a 10.80 ET.
I agree with Steve on using ET to figure H.P. with NHRA cars.Use MPH.Tom
It is hard to say what HP the car is showing because there are a number of things about the car we don't know. Based on my assuming somethings I get this using less than 500 HP. Shifting at 6800 RPM and 7997 RPM @ 1320 feet.
60 Foot ET = 1.2845 330 Foot ET = 4.0715 1/8 Mile ET = 6.5046 1/8 Mile MPH = 101.1140 1000 Foot ET = 8.6110 1/4 Mile ET = 10.4082 1/4 Mile MPH = 125.3550 Stan
The Following User Says Thank You to Stan Weiss For This Useful Post: | ||
Pete McCartney used to like the 670s. He had a 67 goat SSer and a green early bird. Don't know what happened to those cars.
We sent them home one year at Butlers bracket race, with our junkyard 670 400...
1963 Cat SD Clone (old school) streeter 1964 GTO post coupe, tripower, 4speed (build) 1965 GTO 389 tripower, 4 speed, driver 1966 GTO dragcar 1966 GTO Ragtop 1969 Tempest ET clone street/strip 1969 GTO Judge RA lll, auto 1969 GTO limelight Conv. 4speed go and show (sold) 1970 GP SSJ 1970 GTO barn find..TLB…390 horse?….yeh, 390 1972 GTO 455 HO, 4 speed, (build) 1973 Grand Safari wagon, 700hp stoplight sleeper 525ci DCI & 609ci LM V head builds Last edited by J.C.you; 11-26-2021 at 12:07 PM. |
Joel Larkin has been running the Bird. The driver of the GTO was Jay Cason. He's #49 on this list. https://www.dragracecentral.com/DRCS...r1998#indextop I have pics of '67 SS Birds from the early years, sponsored by Stan Long Pontiac, Gay Pontiac, & Myrtle Motors. They're what I call "small tire Super Stockers". The Stan Long Bird was a nat record holder. I figure that one reason why the '68 Birds have been so much more popular for class racing is because of the larger head choice. NHRA allows the much more common #16 & #62 D-ports, as well as the RA2's. Last edited by ponyakr; 11-26-2021 at 12:54 PM. |
While the stock head rules do not allow you to do very much. They do allow any valve job. Exactly what that means and how far that can be pushed I don't know. The question is which casting after a "creative valve job" flows the best?
GT / SS is a totally different animal. You can do all of the porting and filling on the ports you want. They only have to measure under the max port volume cc's listed. Stan
Stan Weiss/World Wide Enterprises Offering Performance Software Since 1987 http://www.magneticlynx.com/carfor/carfor.htm David Vizard & Stan Weiss' IOP / Flow / Induction Optimization - Cam Selection Software http://www.magneticlynx.com/DV Download FREE 14 Trial IOP / Flow Software http://www.magneticlynx.com/DV/Flow_..._Day_Trial.php Pontiac Pump Gas List http://www.magneticlynx.com/carfor/pont_gas.htm Using PMD Block and Heads List http://www.magneticlynx.com/carfor/pont_pmd.htm Last edited by Stan Weiss; 11-26-2021 at 01:11 PM. Reason: Added Picture |
I did something similar with the 12 heads on my 400 for PS racing. No porting allowed, but that doesn't mean you can't change the valves and play with valve job angles. |
