‘70 TA alternator install
I picked up an rebuilt open-faced alternator over the summer and finally got around to trying to install it this weekend. Granted, my 400 RA3 engine is out for a stroker build and am currently running a ‘69 428, but it has all the correct brackets from my ‘70. When I first tried to install it, the bolt ‘ears’ were 180 degrees off, so I clocked it 180 degrees. Then I noticed that the rear bracket (attached to water neck and first manifold bolt) would not line up with the threaded hole in the back. I clocked it another 90 degrees, but now the plug is on the side, not the top, and I don’t think it’s correct.
Interestingly, the ‘70 Firebird Supplement has a drawing of the alternating that looks just like mine, but I don’t see how to attach the rear bolt with the plug on top of alternator. Here is the shot of the rear of the alternator (one on left is open-faced) Sent from my iPhone using Tapatalk
Three times the sound peaks, falls back, peaks again. A throttling back to cruising speed, a dwindling grumble of thunder and...gone. The frogs take up where they left off. |
That’s a early 69 rear case
Clock the rear up to 12 O'clock so connector is up top.
This is a 70...
Agree with Telly, you have a 69 rear case. The bolt hole on a 70 rear case is in the same location as the one on the right. Also, the one on the right looks to be clocked correctly.
1968 Firebird 400HO convertible 1971 Trans Am 4-speed, white/blue |
Here’s the one you need
Thanks Telly. I sent you a PM. Sent from my iPhone using Tapatalk
1970 back
You got the 69 version. Remember 69 trans am alternator is expensive and I imagine so are the backs. You can sell yours,use it, trade ect. I have a 902 with the 71 style back with correct mounting bolt is another option for you
More pics that can help
These are the 70 style only difference I see is the mounting hole is located at 3 o'clock vs 6 o'clock. I learned this stuff hunting down a mystery 1100904 that probably never existed and decided to build 1.
A 1969 alternator
Here is some pics of an original 69 open face pontiac trans am alternator. This will probably help you I hope.
Thank you! Had a family emergency the last couple of weeks so am just getting back to this issue.
Thanks for the photos and explanation!
The Following User Says Thank You to racerboy For This Useful Post: | ||
