Old 04-12-2024, 10:01 PM
fyrffytr1's Avatar
fyrffytr1 fyrffytr1 is offline
Default Vinyl Dye
I need to redo the kick panels and carpet in my 67 and thought I would just use spray dye on both. What do you all recommend for vinyl dye? If I remember correctly the color is dark aqua.
Old 04-13-2024, 08:26 AM
Cammer-6 Cammer-6 is offline
SEM is good
do a wipe with the hottest(slow) lacquer thinner to soften the plastic just before spraying
with carpet the key is to spray an area and work it in with a small stiff scrub brush.
Steam clean and vacuum before dye.
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 04-13-2024, 11:40 AM
burd's Avatar
burd burd is offline
You can order SEM at Walmarts, or go get it mixed up at an automotive paint store.
Just Say No To 8” Flakes
F ire B irds
Old 04-13-2024, 08:47 PM
Rachelsdad's Avatar
I was going to suggest SEM, but held back, as my last experience with it was almost 40 years ago. I applied it then just as described here, and it came out quite well (hard plastic interior parts and carpet; 1980 Phoenix, in dark blue, circa '87).
Lewis
Lewis Rosenthal
'63 Bonneville Convertible
'56 Safari
'82 Firebird SE
Old 04-13-2024, 10:50 PM
fyrffytr1's Avatar
Thanks for the replies. My carpet came from Legendary Interiors about 15 years ago and it has faded badly. I think it was ACC carpet. I can get new carpet for about $200 but that involves taking out the seats and console. I figured I could tape the edges and cover the seats and console then spray it. I will remove the kick panels to spray them.
Old 04-16-2024, 02:41 PM
You know Phil, I recall you dying your interior years ago. I bought my dark aqua dye from the same place based on your results and it turned out great. TCP Global in California. I called them up gave them my factory color code they matched it perfectly.
Old 04-16-2024, 11:05 PM
fyrffytr1's Avatar
I think that may have been on the 65 I had. I bought new carpet for the 67. I did buy a can of interior paint. I think I still have the can in my shop. I will look tomorrow if I get a chance.
Being retired, I don't have time to do anything!
Old 05-25-2024, 04:42 PM
gassman_67's Avatar
gassman_67 gassman_67 is offline
m-40 dark aqua form Ames, color is spot on
https://www.facebook.com/KauffmanRac...6873234225938/
KRE 461,310 CFM 85cc, KB pistons, Eagle rods, Ohio crank KRE custom HR236,Dougs ceramic,Edelbrock Pro Flo 4. Quick Performance 9".
552HP 594 TQ
The Following User Says Thank You to gassman_67 For This Useful Post:
