PS pulley is cast with 8AC cast onto the spokes
Crank is stamped steel or aluminum. Pic of crank pulley: |
Not sure if this is aftermarket but bolts to the stock pulley.
Would this work?
"At no time did we exceed 175 mph.” Dan Gurney's truthful response to his and Brock Yate's winning of the first ever Cannonball Baker Sea-to-Shining Sea... Still have my 1st Firebird 7th Firebird 57 Starchief |
694.1 What is the dimensions of mounting surface to bottom edge of groove and top edge of groove? Bottom diameter at mounting surface and top diameter? Thanks
Check out this guy Larry Groskopf, He's on face book and has the pulleys & Compressor with mounts for sale. He wants $90.00 for the pulleys & harmonic balancer
https://www.facebook.com/groups/2613...0002279058078/ |
![]() Quote:
If you end up with any spare A/C pulleys you want to sell, let me know - I'm looking for the same. Do any of the ones you have, have part numbers on them?
Wat are the dimensions of it?
The deminsions of my pulley where it would sit attached to the haronic balancer are 1 9/16" to the inside grove where the belt would ride - 2 1/4" to the out side of where the belt would ride inside that grove - if that makes any since and the OD of the pulley is 6 1/16". If you wnat pics with a tape against th epulley let me know.
This is the bracket you need for the alternator to use a 61 - 63 A/C compressor mount:
https://www.ebay.com/itm/266355695031 As I stated earlier Franks Pontiac has the flat plate that bolts to this Alternator mount. |
![]() Quote:
The only missing piece of the puzzle is the bolt on single groove pulley and correct PS pump pulley.. |
