Old 11-19-2025, 10:15 PM
ScottK. ScottK. is offline
Default Pontiac Victor Jr
Here’s a little info on the Victor Jr looks promising!Looks like it’s the same height as a RPM intake.
https://youtu.be/gYhKD0DENug?feature=shared
The Following 5 Users Say Thank You to ScottK. For This Useful Post:
Old 11-20-2025, 01:47 AM
R 70 Judge's Avatar
Pretty cool stuff. I bet the EFI version sells well.
James
1970 Trans Am
The Following User Says Thank You to R 70 Judge For This Useful Post:
Old 11-20-2025, 08:36 AM
PAUL K's Avatar
PAUL K PAUL K is offline
It looks to be missing a second mounting bolt boss for the accelerator cable bracket used on 72-81 Firebirds
Go fast, see Elvis!
Old 11-21-2025, 12:37 PM
I just saw a video (from maybe SEMA?) from Edelbrock. Said it was developed with Butler and is about the height of a Performer RPM. So far good for a 700 HP motor has not tested it on higher HP motors. The port dividers look a little thinner.
Old 11-21-2025, 01:52 PM
Bill Eveland's Avatar
This is the pic I posted here a bit back from Butler. Nice they have an efi version as well
Illinois Outlaw Gassers
6.27@107
9.97@131
The Following User Says Thank You to Bill Eveland For This Useful Post:
Old 12-01-2025, 09:33 PM
blueghoast's Avatar
Looks like a straighter runner to the port also. (yeah maybe)
GT
Old 12-02-2025, 12:32 PM
Formulas's Avatar
Formulas Formulas is offline
Wondering carb placement fore. n aft. ... Over and under pricing guess ?
Old 12-03-2025, 10:29 PM
ErikW's Avatar
ErikW ErikW is offline
Looks just like my Holley Street Dominator I converted to EFI.
1964 GTO
9.76 @ 137mph
2009 G8 GT
The Following User Says Thank You to ErikW For This Useful Post:
Old 12-04-2025, 01:26 PM
GOAT8U2's Avatar
GOAT8U2 GOAT8U2 is offline
Good to see efi is already tested and built in, should be a nice addition to the market.
69 GTO Convertible, 4000lbs
462ci, 606tq/569hp - 93 oct @ 34 deg (207psi)
11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10", Rock Valley SS Tank, Dual 450s, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" & Borla Pro XS 3", Alum Rad & Dual Fans, 12:1 Box, UMI Arms & Viking Berz Fr + Rear CO Shocks, Hella UP5.0 Vac Pump, 12 Bolt, 3.73, 33 Spline
Old 12-04-2025, 03:51 PM
RocktimusPryme's Avatar
How would this compare to the Northwind? Ill be at PRI next week. Ill get a look at it up close.
Ive still never seen one of those TRS carbs on a vehicle even though they have been out for a while now.
