Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 07-15-2004, 08:10 PM
tom s tom s is offline
we put one in the RA V short deck motor,maybe Ken can comment as he did the installation.Tom
  #62
Old 07-15-2004, 10:31 PM
lotzofn2o's Avatar
lotzofn2o lotzofn2o is offline
Can any send me a pic of the setup, the link wasn't availible on my pc. [email protected]
On the bumper or put it on the trailer
  #63
Old 07-16-2004, 04:13 AM
Brian '74's Avatar
John, my server was down. Here are the pics:
  #64
Old 08-14-2004, 07:58 PM
GTO's Avatar
GTO GTO is offline
Just got mine. Looks like a quality piece! I'll be installing it this fall and will let you guys know how it fits. ... Eric.
Runner Up Q16 Norwalk 2013!
  #65
Old 02-27-2005, 10:45 AM
simsb52 simsb52 is offline
Well,I took the engine out of the circle track car and inspected it after last season of racing in circles. everything looked great! All that was needed was the over head set. I didn't need to take the engine out for that, I know, but I wanted to make sure that the engine would make it thru the next season. I still make the roller bearing cam plate if any are interested. Price is up a bit to $220 plus shipping.
Thanks....
Scott Sims
Sims Performance Machining
Scott Sims
Sims Performance Machining LLC
P.O. Box 184
Elizabethtown, Indiana
47232
phone... 812-350-8637
[email protected]
  #66
Old 02-27-2005, 10:48 AM
One other thing.....Tom S. Was that one of my cam plates on your RA V engine that I read about in HPP?
Scott
Scott Sims
P.O. Box 184
47232
[email protected]
  #67
Old 02-28-2005, 12:09 PM
Junkyard Dog's Avatar
Is this better than Butler's step design bronze bushing (the web site claims less wear on the plate because of the bushing)?
Badder than old King Kong
-Jim Croce
  #68
Old 02-28-2005, 12:54 PM
Scott,yes it was in the motor.I need to talk to you.Email me from my profile.Dont PM.Tom
  #69
Old 02-28-2005, 09:41 PM
Junkyard dog....I personally think its better. Mine gives you a roller bearing on both sides of the plate. It controls camshaft end play with those bearings. Its also is oiled using the factory oiling system with no mods to the block or cam.
Scott Sims
P.O. Box 184
47232
[email protected]
  #70
Old 03-01-2005, 11:17 AM
2manyponchos's Avatar
2manyponchos 2manyponchos is offline
JunkYard Dog, my feeling is that the Sims Performance roller bearing cam plate is superior to the bronze bushing. I agree that the bronze bushing will decrease friction between the cam gear and thrust plate, but you still have the same friction between the cam and thrust plate. If memory serves correct, the cam tends to ride forward (toward thrust plate) under acceleration and rearward (toward rear of block) on deceleration. I do not believe the bronze bushing will improve friction or wear characteristics on acceleration. The Sims Performance setup provides roller bearings on both sides of the thrust plate which will decrease friction on both accel and decel. Food for thought...
P.O.S.I - It's not just a club...it's an addiction!
  #71
Old 03-01-2005, 02:50 PM
Thanks.
-Jim Croce
  #72
Old 03-01-2005, 04:43 PM
slowbird's Avatar
slowbird slowbird is offline
How many people are running these. Has there been any issues with them. Im interested in one but it would go on a car that sees some miles and the last thing Id need is for it to come apart.
  #73
Old 03-01-2005, 05:01 PM
I have one on the engine going to the dyno this month. Straight forward installation. Good quality pieces.
  #74
Old 03-01-2005, 09:25 PM
pontiacjeff pontiacjeff is offline
So am I correct in my understanding that this setup controls front and rear movement? So true cam endplay can be set. Not relying on the rear cam galley plug or the stock retainer plate for end to end movement.
If so, I will be contacting you very soon as I am about to install a solid roller cam in my engine.
Jeff Ianitello
  #75
Old 03-02-2005, 06:47 AM
Pontiac Jeff...Yes it does control endplay both ways. When we dyno tested this concept, we concluded that this control helped in the HP gain that we saw on the dyno pulls. So it was probably a friction reduction and controlling the timing @ WOT that helped with the gain.
Slowbird.....I have sold 25 sets to date. With only one complaint. That was...And Iam ASSuming here...was with a setup that might have not been oiled correctly. The setup was with a roller bearing cam where the roller bearing replaced the standard cam bearing. In doing this .... you block off the oil passage going to the cam beaings and rely on "splash" to oil the roller bearing and this works. But, My setup relies on the oil supplied to the No.1 cam bearing for oil to the bearing in the cam retainer plate torrington bearings. It is a positive oiling system with oil being pumped through the bearing for positive oiling. When you use roller bearings for the cam....This positive oiling is lost. there is a way to correct this, but it is unproven so far.
Again, I run this setup in a circle track car with Absolutly no problems.
Thanks ....Scott
Scott Sims
P.O. Box 184
47232
[email protected]
  #76
Old 03-02-2005, 07:53 AM
slowbird's Avatar
So what all has to be done to run this? Would I have to send my gears to you to get fitted? What does the $220 include?
  #77
Old 03-02-2005, 08:16 AM
I have the one that Scott is talking about.He is going to remachine the retaining plate to gather oil and feed the bearing.Great piece and want to get it back into the engine ASAP.Tom
  #78
Old 03-02-2005, 10:29 AM
Slowbird...If you want... you can send me your cam gear(sprocket) and I'll machine it for you and send it back with all needed to reinstall on your engine for $150. $220 is for a complete new kit. So if you want ...I'll machine your gear, no problems. Please include about $10-$15 dollars for shipping back to you for a total of $160-$165 depending on where you live from zip 47232
Thanks...Scott
Scott Sims
P.O. Box 184
47232
[email protected]
  #79
Old 03-02-2005, 02:44 PM
slowbird's Avatar
simsb52 I sent you an email.
  #80
Old 06-02-2005, 09:13 PM
T-Mac T-Mac is offline
Hi Scott,
I am interested in one of your timing chain sets.
After throwing away numerous cam retainer plates that were too chewed up to re-use, its time to step up.
Looks like an excellent product, I can't believe nobody else thought of this years ago!
9 hp and 10 ft lbs of torque is amazing, its a win - win deal.
Do you have any sets in stock?
Todd
