Old 11-20-2003, 12:11 AM
yankeeralph yankeeralph is offline
I need to change the driven gear in my TH350 from a 39 tooth to a 45 tooth, but I found out the 45 tooth will not fit in the present holder(retainer) for the 39 tooth (slightly larger stem diameter as well as outside tooth diameter). I noticed that the present holder has numbers on the outside, like 36, 37, 38, 39 which I now assume is the size of the speedo gear that can be installed in this holder. Do I need to get a different holder for the 45 tooth (where?) or do I have the wrong speedo gear, or worse yet do I have to get a different drive gear for the transmission shaft? Thanks
Old 11-20-2003, 10:20 AM
johnta1 johnta1 is online now
M-38 sleeve for 40 through 45 teeth gear #1362285
Don't know how up-to-date the factory number is now.
They might be able to cross-reference it,if it's out-dated.
johnta1
Old 11-20-2003, 06:52 PM
Darrell's Avatar
Darrell Darrell is offline
Get ahold of Scott Esterelle at summit and order the housing. I just did the same thing. Tci sells them but they have a minuminum order, so they told me to get it through summit. It was less than $10.
ET 13.2 and spinning like a mother
ET 12.504
MPH 107
3940 lbs
Old 11-20-2003, 11:03 PM
pont406's Avatar
pont406 pont406 is offline
You could also check with one of your local transmission shops, that's what I did,they had bins of these speedo parts to sort thru. They can help you figure out what gears you need too. I just did this same swap on my 66 Lemans!
1966 Lemans, 3700Lbs, 406 ci, #96 Heads, Crane 467/494 cam, RPM Intake, Q-Jet, 11 inch Converter, 3:90 gears, 3 inch exhaust, Best ET 12.62@107 MPH 414ci shortblock coming soon!
