Old 09-25-2003, 09:36 AM
lil64gto lil64gto is offline
I took my 64 out for its first voyage since doing a frame off and noticed that the speedo is not reading correctly.
I took the original 300 out and replaced it with a TH350. The speedo is reading about 13 mph faster than what I an really going. Can I take the speedo gear out of the 300 and put it on the TH350?
Thanks,
Jim
http://www.geocities.com/jims64gto
Thanks,
Jim
Old 09-25-2003, 12:33 PM
gotpontiac gotpontiac is offline
I think you will have to change the gear on the output shaft to correct your seedo.
Greg
1969 Firebird/400/th400/3.42:1 rear
1/4=? MPH=? (WIP)
1983 1/2 ton Silverado/lwb/305 (89 FB)/
MSD ign/Mallery coil/83 intake/
700-r4(rebuilt w/shift kit and corvette servo)/
3.73 gears/31x10x15 all terrains.
10.9 1/8 mile. 17.xx 1/4 mile
1996 C2500/6.5L TD/4L80e(shift improved),4" exhaust
cold air intake, mechanical WG controller
3.73 gears/265-75-16 w/Eagle allows.
2002 1500 Suburban/stock
1986 Fiero GT,needs engine.
Old 09-25-2003, 07:35 PM
merlin merlin is offline
trt www.triauto.com they have all the stuff you need to fix your speedo.
Old 09-25-2003, 07:40 PM
Merlin
That address doesn't work. Is it correct?
Jim
