Old 09-01-2003, 03:31 PM
72 LeMans 72 LeMans is offline
While putting a Torker intake on my 400, I noticed that the bracket that holds the throttle cable is about an inch too short to meet up with the bolt holes on the torker intake. Anyone else face this problem. Any suggestions. Thanks
1968 Pontiac GT0-400/M-21/3.90 Burmuda Blue with White Royal Bobcat stripes
1972 Pontiac LeMans-455/TH400/3.55's Cardinal Red. Hoping for high 11's
1977 Pontiac Grand Prix SJ. No engine/trans. Body straight. For Sale...Make Offer
1968 Pontiac GT0
1972 Pontiac LeMans
Heart Of Illinois GTO club member
"This aint no damn Chevelle"
1968 Pontiac GT0
1972 Pontiac LeMans
Old 09-01-2003, 04:56 PM
firechicken's Avatar
firechicken firechicken is offline
On my '77 the bracket needed to be shimmed up about 1/2 in. to align with the carb properly. I just used some steel fuel line and longer bolts to raise the bracket to it's proper location.
Old 09-01-2003, 05:48 PM
bs78ta's Avatar
bs78ta bs78ta is offline
When I put my plate system on my TA I had the same situation. Spacer and longer bolts will cure your problems.
Butch
Butch
Old 09-01-2003, 06:01 PM
Its not that problem (yet) its that the other bolt hole is over an inch too far from the other one. Any ideas for that. THanks for the other part. I will probably need that one i get this figured out.
1968 Pontiac GT0
1972 Pontiac LeMans
Old 09-01-2003, 07:17 PM
A.W.Dille A.W.Dille is offline
I used a bracket, throttle cable, and gas pedal from a 72 Grand Prix on my 71 GTO and everythiong mated perfectly. Yes I have the old Torker intake with an 800 spreadbore Holley setting on top of my 400.
1971 GTO,72 400, stock bottom end, 670 heads, Lunati BMII cam, headers, iron intake Q-jet, four speed. Best 60 ft 1.806in 2004. Best 1/8th mile e.t. 8.46 with 3.55 open rear
85 Grand Prix, 70 400, casting 62 heads stock rebuild, Turbo 350 trans 78 800 cfm Q-jet modified as per Cliff Ruggles book.
87 F350 6.9 4 speed dually
A poor man has poor ways.
Old 09-01-2003, 07:45 PM
cuz68's Avatar
cuz68 cuz68 is offline
From what I have read the old torker is not as good as the 68-72 stock intakes?
Cuz68
Old 09-01-2003, 07:46 PM
My original bracket had the same bolt spacing as the Torker. You must have the wrong bracket from your stock intake. I'd try to source another one from a factory intake.
Old 09-01-2003, 10:10 PM
Spend 15 bucks and get a Spectra bracket from Auto Zone, it will fit im pretty shure.
Mike
Old 09-02-2003, 04:09 PM
Blackfoot Blackfoot is offline
Get a Lokar cable and throttle bracket assembly.(two separate parts) You'll have to remove the assembly on the firewall where the cable passes through the firewall, remove the old cable, drill it out to 7/16, save your original clevis pin on your accelerator pedal. Throttle cable bracket is self explainatory but it does come with instructions. Abut $40 for the whole shebang. Nice set up, I'll never worry about mine again. Here's a pic.
I've got a babys brain and an old mans heart,..............
Old 09-02-2003, 09:10 PM
Thanks Blackfoot. I'll check that out. Thanks for the pic too!
1968 Pontiac GT0
1972 Pontiac LeMans
