Old 07-03-2004, 04:43 PM
mystry mystry is offline
I have a 1975 Pontiac Grand Lemans with a 400 V-8 4bbl in it. I have replaced the coil, cap, and now the dist. in it. It would run approx 200 miles after I replaced each of the coil and the cap. Then it died. The last time it died it backfired and died also. I had my friend replace the dist, which he thought was the problem, no help. The wires and plugs are good, the fusable link is good. It'll crank but not fire. Any idea's?
Old 07-03-2004, 06:07 PM
Still HEI?
Check for voltage going to the distributor.
Have you replaced the rotor? Used the correct coil?
This also assuming the distributor is timed right,wiring is good.Wire not loose inside the distributor.
Old 07-03-2004, 08:06 PM
george kujanski's Avatar
Older HEI's have a known failure mode. The pickup coil wires fracture and go intermittent, then break totally.
Check if you get spark at all. If not, unplug the pickup coil and check if it is open (high resistance).
George
Old 07-06-2004, 10:42 AM
RAJNWDY's Avatar
RAJNWDY RAJNWDY is offline
I would change the module and check the ground up in the cap for the coil. If you have a tach, disconnect it and see if it runs. the tach may be grounding out.
RDRR Custom Fabrications
....A fictitious company doing fictitious work....
