Old 10-21-2003, 05:23 PM
Fireguy615 Fireguy615 is offline
OK guys I need some help here. When I drive my '64 Goat at nite with the headlights on, I smell a rubber-burning smell and hear a rapping noise from under the hood. If I turn the light off, it all stops. Any ideas? This one has me confused. Thanks fellas.
Scott
Scott
Old 10-21-2003, 06:49 PM
jarhead's Avatar
jarhead jarhead is offline
Check the voltage regulator on the firewall, could be over charging with the load from the headlites. Also with the car parked in the dark, car in neutral, headlites on, open the hood and see if you can localize the noise and smell. It could also be a combination of the belt and voltage regulator. Maybe the alternator is draging with the load on.
More pictures of my Goat:
http://www.geocities.com/mm5581/index.htm
More pictures of my former Goat:
http://www.barrett-jackson.com/appli.../w_search.aspx
My old car is listed in the 2007 Scottsdale Auction, Lot #1016 - $60K
And in the 2008 Scottsdale auction, Lot #960 - $80K
Eventually sold by Brighton Motor Sports in Scottsdale, AZ -$89,900
Old 10-21-2003, 07:44 PM
64tempest 64tempest is offline
Depending on what options you have and what has been modified over the years look at yor alternator or voltage regulator,
Jughead has a good way of checking if your e-brake is in working order, otherwise dont try that byyourself Ive heard of to many horror stories trying these things alone !!!
