Old 09-23-2003, 05:28 PM
Brent67CAT Brent67CAT is offline
I have a 67' 4 DR HT Catalina with a 400 2bbl with 143 heads and single exh. I would like to put on some headers and dual exh, but there doesn't look like there is much room in the bay. Any suggestions? Thanks Brent
Old 09-23-2003, 09:21 PM
Ccass's Avatar
Ccass Ccass is offline
Administrator
If it is column shift, I believe you have a problem. If not, Doug's headers makes an excellent set for big Pontiacs. They are quite expensive(over $400) With your combination, you may want to take that money and first put it into other power adders. For starters, I'd get a 4bbl intake/carb and convert to dual exhaust.
Fool around, Get hurt, don't come crying to me.
Old 09-23-2003, 09:46 PM
Unfortunately I do have a column shift ( th400 )
Are there any performance manifolds out there
Old 09-24-2003, 10:14 AM
Ccass's Avatar
Administrator
yes, The long branch manifolds. I'm not 100% sure they will clear your column shift linkage though. I would post an additional topic in the Fullsize tech forums.
Old 09-24-2003, 05:39 PM
can_am4me can_am4me is offline
I had a '67 Bonneville in high school. and we put a set of GTO headers on, with a few modifications.
We shimmed the motor up with a 3/8 in steel plate under the motor mount( just drill a large hole in the plate, slide it in, and bolt up the engine)
We had to ding a couple of tubes in a few spots (can't rememeber where, long time ago!)
These 2 mods gave enough clearence. I would suggest finding a junk set of GTO headers first, and giving it a try.
Putting some "Can do" in my Can Am
